1971 Journey
Old 01-19-2019, 03:43 PM
  #1401
CraigH
CraigH's Avatar
Thanks guys, am looking forward to the reassembly.
A little nervous about the headlight doors but should be fun.
Lots if masking tape needed to protect things.
Old 01-19-2019, 05:53 PM
  #1402
Primoz
Primoz's Avatar
2017 C3 of Year Finalist
Yes Craig, use a lot of masking tape around the headlights! I learned that the hard way! I chipped my paint when doing this!
CraigH (01-19-2019)
Old 01-20-2019, 09:30 AM
  #1403
BLUE1972
BLUE1972's Avatar
Received 1,130 Likes on 733 Posts
Targa Blue
Primoz (01-20-2019)
Old 01-21-2019, 04:10 AM
  #1404
CraigH
CraigH's Avatar
I think Bridgehampton Blue has some more green tones than Targa blue.
however as someone said before there are so many different tones to it if you look at cars that have been re shot.
Old 01-28-2019, 11:03 PM
  #1405
Metalhead140
Metalhead140's Avatar
C3 of Year Finalist (track prepared) 2019
Stunning!
Old 01-29-2019, 07:46 AM
  #1406
69ttop502
69ttop502's Avatar
Looks terrific! Still following!
Old 01-29-2019, 11:07 AM
  #1407
OldCarBum
OldCarBum's Avatar
Received 4,699 Likes on 2,938 Posts
Very nice.
Old 01-31-2019, 04:27 AM
  #1408
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Car looks GREAT Craig! You're in the home stretch now...
Old 02-12-2019, 12:49 AM
  #1409
CraigH
CraigH's Avatar
I fitted new door sticker pins.
They were nice stainless steel ones with 2 washers under each.
All worked well after some minor adjustment then I put the Vette up on the jack.....
There is always some minor flex but the passenger door would hardly open as the pin was too short by less than half a mm
Had not seen this before.
Placed my crossmember jack under the front and gave it a few turns by hand and then all worked great.
I measured the new one piece stainless door pins and found they were about 2 mm shorter than the originals.
When compared the black aftermarket ones about 4-5 mm shorter.
Possibly a third washer or thicker ones is needed :-)
Old 02-12-2019, 12:52 AM
  #1410
caskiguy
Support Corvetteforum!
caskiguy's Avatar
What, no pictures ? Say it ain't so. lol
Old 02-12-2019, 12:59 AM
  #1411
CraigH
CraigH's Avatar
I spent a bit of time on the front apron today.
Looked fairly good but on close inspection it could do with some more work.
Started by sanding it all flat with 2000 wet and dry.
Followed by 3000 wet and dry, then some buffing compound. you can see the progress.
After an hour or two I am happy with how it looks..
Shame it won't be seen once bars etc are on and car is back down.
Old 02-12-2019, 01:00 AM
  #1412
CraigH
CraigH's Avatar
OK I will take one :-)
Its in original post now :-)
Old 02-12-2019, 04:12 AM
  #1413
SB64
SB64's Avatar
Than you for taking these great pictures of the lower valance or panel. I am working on that area know which was heavily damaged. Your pictures will be a big help as to what things should look like.
Old 02-12-2019, 04:18 AM
  #1414
SB64
SB64's Avatar
Craig, is there a riveted small plate attached to that panel for screwing the end of the outer part of the grill. That is all missing on my 71 I think and I was trying to remember what it all looked like.
Old 02-12-2019, 04:43 AM
  #1415
CraigH
CraigH's Avatar
Hi Roger
I assume this is what your after
Old 02-12-2019, 05:40 AM
  #1416
SB64
SB64's Avatar
Hi Roger
Yes , that's it , fantastic. I will have to see if I can re make that flat lip. Just curious what that electrical box is on the inner fender.
Thank You for taking the time to take that picture.
Old 02-12-2019, 05:47 AM
  #1417
CraigH
CraigH's Avatar
It’s my fuse and relay box for headlights and thermo fans Roger
its integrated into original harness the wrapped again.
To 1971 Journey
Old 02-12-2019, 10:53 AM
  #1418
Primoz
Primoz's Avatar
Craig nice work. I suggest good quality wax or sealant for that front apron so you can protect it as best as you can.
Craig can you please look at the front driver side at the radiator support if there are any wires bolted to the support for ground?
I have some wires there that looks like they are detached and I don't know where they should go.
Old 02-12-2019, 11:16 AM
  #1419
OldCarBum
OldCarBum's Avatar
Very nice!
Old 02-12-2019, 11:55 AM
  #1420
caskiguy
caskiguy's Avatar
Thanks for the pictures Craig, I feel better now.
Quick Reply: 1971 Journey
