1971 Journey
#1201
Thanks for all the feedback.
I get what your saying DUB, the fact that it is bonded to the hoop of the birdcage means it should not move much.
The main flex would be taking the rear window in and out, especially if it is very tight.
I now have it all back to glass.
There was original paint then VPA, Sealer, Spray putty etc then the final paint.
I was able to get most of it off with a razor blade then sand the original paint away.
There is still a couple of cracks on the outer edge where it comes down towards the sails.
I will glass them up and grind out the side vertical joins and do them again.
In the center under the halo is a crack as well or possibly its a join.
The correct name is Evercoat Fiber Tech
http://www.evercoat.com/product-deta...art/100633/us/
knowing that you seem to really get into repairing your major cracks in the body correctly...these should not come back.
Mainly because...even though I LOVE VPA...if the area is not correctly prepped and it used correctly...it can fail.
DUB
#1202
So it would appear that the top cracks were from some previous repairs.
They do not seem to flow into the fill panel under the halo.
However it does have a fine crack in the middle
The seam does not look that bad at all, except on the passenger side where it is a mix of filler types.
#1203
At least your repairing it correctly now Craig
It's actually a join under the centre of the halo and not a crack. That section must be made up of two panels, I had the same on mine. I guess the factory didn't bother to smooth it out too much due to its location.
You should have the VPA by the weekend.
#1204
#1205
The line in the center is a bonding seam like the ones on the sides. Grind and fill.
DUB
#1207
It's in the mail Craig.
VPA is very thick stuff so you need to stir it well before use.
Also it drys very hard, so it's best to start sanding it while it's still soft. Usually a few minutes after applying it. If it clogs the sandpaper then it's still a bit too soft but it doesn't take long to harden up. Just don't leave it to long before you sand or you will be in for a workout!!!
#1208
Good Luck, I think you will like it once you get the dynamics of it.
#1210
I think Roger meant to type 80 grit and not 180 grit. Sanding with 180 grit right of the bat is futile.
For shaping /contouring and getting it down use 36 grit...then switch to 80 grit depending on how bad it is.
Then when you have to blocked with 80 grit...go over it with 180 grit and prime it.
That 'sweet spot' is when it is still soft enough to not fall off or peel away from the panel when you sand it with the 36 grit...but it is still soft enough to clog your paper...but yet hard enough to NOT STICK in the grit of your sandpaper and ruin it...but hard enough so when it does clogs your sandpaper...you can take a paint stick and slap the paper and the VPA falls right out of the grit of the sand paper. THAT is the sweet spot....if you do not want to waste good sandpaper due to going in while it is still gummy and clogging your sandpaper.
If you need to re-apply the VPA...make sure it is on a surface that is at least 80 grit scratch and clean. And also make sure any areas of the VPA that were not sanded with your sandpaper due to being low.,...you go in and make sure they are scuffed well.
Applying VPA on VPA that has not been sanded is A BIG NO-NO.
But do as you see fit.
DUB
DUB
#1211
DUB
DUB
That "sweet spot" sounds very hard to hit. Will give it my best try though.
#1214
Back in town yesterday afternoon and I had a parcel from Brad with some VPA. Thanks so much.
Looking forward to using it on my Halo panel seams.
But first a bit more glassing around the exhaust fill panel and rear bumper mount.
#1215
Now the exhaust fill panel.
Looks like the bracket cutouts were done with a bread knife so I will remake them and cut again.
Also for some reason one end was square edges and the other round where it bolts on.
Another previous repair.
Ground out back of each part and taped it up ready for glass. Used plastic sheet to build up the space where needed to hold the glass.
Then glassed it all in.
Once dry i will smooth it out and the flip it over and re glass the front.
#1217
Received 2,878 Likes
Hi Craig,
As usual your devotion/willingness to doing the amount of work needed in order for things to be RIGHT is remarkable!!!
The fact that it appears that you're working with an aftermarket exhaust panel isn't helping!
Regards,
Alan
Once again "BETTER is the constant enemy of good"....and you prove that over and over!
Regards,
Alan
#1219
#1220
FOR WHAT IT IS WORTH:
This is not an opinion... it is fact.
That lower exhaust filler panel is NOT an aftermarket one, it is original GM. And it is an early SMC one at that. And YES...it can be actually thicker than a polyester press molded one one earlier years...and a bit heavier also.
The photo shows that there is no hand laid fiberglass texture to the inside of the lower exhaust filler panel...thus is was made using two molds.
DUB
DUB
