1971 Journey
#1042
Fixed a hairline crack at the bottom of the headlight hole. Ground it out and layed it up with glass.
Sanded back.
Fixed some cracks in door paint caused by me when I got something caught in the door.
At the top edge there is a piece I removed that was cracked. Looks like it bonded to the metal backing. Can I just glass it up or am I Better using something like fiber tech filler ?
My initial thought is grind it down then glass it up.
Sanded back.
#1043
Received 2,878 Likes
Hi Craig,
At that upper location on the door aren't you seeing the 'back-side' of the steel door frame that the fiberglass 'skin' was bonded to.
I'd think you can do a typical fiberglass repair for a place where a small amount of the fiberglass is missing.
Regards,
Alan
Regards,
Alan
#1044
Hi Craig, I think you could glass it up or use Fibre tech for the repair. The fibre tech would be easier.
Just make sure you taper the edge of the repair right back and not just fill in the hole or else it will be visible through the paint.
#1045
I sanded back the upper corner of the door and decided glass would be better.
Decided to match the upper shape of the passenger door.
#1046
A couple of cracks on passenger side near the wiper door.
First glass, will need another layer to finish before fillers.
Took wiper door and grate off then decided if I am doing this i may as well clean out the entire wiper area.
Took out the wiper door mechanism to get more room to do glassing and soon the wipers, wiper gearboxes etc etc.
Cant help myself
Cant help myself
#1047
Drivers side vent was always a bit tight so i have opened it up on lower edge to get more adjustment.
Also cleaned up the glass area inside a bit.
One thing i did notice is that when the car sits up on the Quickjack the vent was slightly tighter than on the ground so I have used a couple of jack stands under sway bar mounts to simulate the normal state.
Did not notice door gaps change or anything like that but there obviously must be some flex with when in the air.
Primoz (11-06-2017)
#1048
The wiper door and wiper mechanism came out way easier than i though.
Cleaned up all the loose and crumbling sealer that looks like it was put on with a mop.
Re sealed all the seams with new sealer - 227 Sikaflex. Let it dry for a few days.
Masked it all off.
Next step was Dupli-Color Bed Armor. Nice finish and seals it all as well.
A few coats and let it dry.
Masked it all off.
#1050
Both the wiper assembly and wiper door assembly are sitting on my garage floor ready to get disassembled, cleaned etc.
However I may do that while the Vette is getting the paint work done.
Now I need to get back to fixing cracks in the front glass
#1051
Primoz (11-10-2017)
#1052
Thanks for the observation and picture of the canister Alan.
My 71 was missing it and had no mounting holes in the inner guard due to a previous repair.
It's base is close to the splash shield but not touching.
An easy fix
An easy fix
#1053
CraigH (11-10-2017)
#1054
I am getting closer. Once I get all the glass repairs done i will do a thin wipe of filler and then then painter can finish up.
Repair to passenger siide vent area, found a few cracks.
#1055
The shape of the hood surround was not correct on drivers side and possibly allowed some flex that caused minor cracks. (Also missing the fender to the headlight support bar bracket would not have helped - fixed that a while back)
Built up a mould with aluminium and plastic then laid it up with glass. Still another layer here and there needed to finish. But its wet today and not perfect for glassing.
Passenger side had minor crack that is now done.
I know its not exactly how it should have been but better than the previous fix.
#1057
Started working through my build thread and replacing all the referenced images in Photobucket with my own image storage server.
Had migrated all my images to Zen Photo on my own hosted server.
Takes a long while even with scripts to replace the image references, am about 30 pages through :-)
#1058
vette
A little off base but I noticed the stands you have in the front of the car. Might be nice to check them out for others when you have a chance. Everything you are doing looks really nice. I have also been adjusting some things that may not be original but better.
RVZIO
RVZIO
#1059
The front stands are just used under the sway bar brackets and just touch when the Quickjack is at its lower settings.
They are not holding the car up at all just ensuring minimum flex in the front when it stands up for extended periods.
