1971 Journey
Old 02-23-2013, 05:55 PM
  #401
CraigH
CraigH's Avatar
I needed to repair one of the thermostat housing threads as I had used a spring washer under the long bolt (thinking I was doing the proper thing) but it caused it to strip as it did not get enough threads before it got higher torque.
So I got to learn about Helli coils.
Started by drilling it out, then tapping with a larger size.
Then insert the helli coil using the tool provided.
Snap off the insertion tang and its as good as new, possibly better.
  #402
CraigH
CraigH's Avatar
I have completed the front suspension (just sway bar to go).
Primoz (04-21-2022)
Old 02-23-2013, 05:56 PM
  #403
CraigH
CraigH's Avatar
Using the Borgeson integrated steering box means the column needs to be shortened.
To do this you collapse it a few inches from its base.
Not an issue according to Jim Shea, one of the original designers of the column.
So I had the length about correct but when I inserted then column to the steering box the steering wheel was way off being centered.
So I double checked the box was in its center position so I needed the column to have its flat part of the spine upwards.
However my wheel was not correct in that spot.
After reading lots of documents on this I believe my column has been pulled apart previously and not put back properly.
So it seemed like a simple fix
Undo the top bolt.
Using a puller extract the top assembly.
Then put it back in the correct position.
According to Jim when they made them they notched the top point to help assembly.
So I aligned that notch and re tightened it down.
Now it lines up great.
Just need to prep it all and repaint it before final assembly.
  #404
CraigH
CraigH's Avatar
Radiator back in and the electric fans fitted and wired up.
You can see how much clearance I have to the upper A-arm and to the lower radiator hose.
Wired up.
Old 02-23-2013, 05:57 PM
  #405
CraigH
CraigH's Avatar
A few under shots.
Primoz (11-05-2018)
  #406
CraigH
CraigH's Avatar
After starting it up and letting it get up to temperature I had a small leak in the return line at the steering box.
Picked up a 5/8" flare spanner and gave it a bit more and now it seems to be ok.
Fans seem to keep it cool, only needed one to hold it at temperature in the garage.
Now to move onto the front bearings, hubs, rotors and brakes and I can take it down for an exhaust.
Sounds rather nice with just the headers :-)
  #407
CraigH
CraigH's Avatar
Rebuilt the front calipers this morning.
New o-ring pistons from VB&P.
Cleaned the bores with scotchbrite then painted on some brake fluid as well as on the o-rings and inserted them.
Then tapped outer seals in place.
Bolted together with new o-rings for the fluid passages.
Couldn't get past 105 lbs/in with the main bolts - will need to find someone heavier to hold them or a large vise.
Old 02-23-2013, 05:58 PM
  #408
CraigH
CraigH's Avatar
My replacement spreader bar came from Speed Direct today.
A bit of a difference to the one sent originally.
Bolted it up to test fit.
  #409
CraigH
CraigH's Avatar
Ready to do the front hubs now.
Old bearing shells tapped out and new shells pressed in.
Old 02-23-2013, 05:59 PM
  #410
CraigH
CraigH's Avatar
Packed the bearings with grease and fitted them to the hubs.
On the car, not fully seated yet.
  #411
CraigH
CraigH's Avatar
Rotors ready to go on.
Old 02-23-2013, 06:00 PM
  #412
CraigH
CraigH's Avatar
The service manual says to tighten the front bearings down to 12 ft/lbs then back off one flat on the castle nut.
Hmm, I dont have a socket big enough.
Lots of sites say just use channel locks to do it and adjust till wheel does not have any movement.
Never done it before so want to do it properly.
I ended up using the following method.
Torque the nut down to 15 ft lbs while rotating the rotor.
Back off the castle nut then torque it to between 50 and 60 in lbs the insert split pin.
Old 02-23-2013, 06:01 PM
  #413
CraigH
CraigH's Avatar
Got the Rotors fitted and set the runout for them.
New Brake lines.
Bled the Fronts.
Have to get the car down and rear wheels off to do the backs.
  #414
CraigH
CraigH's Avatar
Not sure if I had a slight issue with one of the rotors machine work as it was offset too close to the caliper on one side.
3/8" flat washers spaced it out perfectly till I can get a proper spacer plate to go between the hub and the rotor.
Old 02-23-2013, 06:02 PM
  #415
CraigH
CraigH's Avatar
Sway bar ready and now fitted.
  #416
CraigH
CraigH's Avatar
So wheels on and ready to check ride height.
Hmm a little low but I still have another inch at least I can go down from here.
Old 02-23-2013, 06:03 PM
  #417
CraigH
CraigH's Avatar
Settled on this height for now.
To 1971 Journey
Old 02-23-2013, 06:04 PM
  #418
CraigH
CraigH's Avatar
Nice to get the car outside again.
Old 02-23-2013, 06:05 PM
  #419
CraigH
CraigH's Avatar
The lower apron needs to be sealed to force as much air into the radiator and not down under.
originally there was some bitumen rubber pieces in there but I uses 3mm rubber and attached it with weatherstrip adhesive.
Old 02-23-2013, 06:06 PM
  #420
CraigH
CraigH's Avatar
December 2011
The Steering column just needs a new isolating part for the head and it will be done.
In the meantime it has been cleaned and painted. There were cracks in some of the ABS parts that were glued with MEK, coated in superglue gel then normal sand, filler etc.
Quick Reply: 1971 Journey
