Overheating is an Understatement
If it overheats at idle, it isn't a radiator capacity issue. If it overheats at speed, it isn't from lack of airflow (not a fan problem.)
You still didn't say if this prob just started or not, but I think your water pump failed, or you have some blockage keeping water from the radiator.
If the problem just started, did you change something, or did it unexplicably appear?
You are not getting too fast of water flow, especially if the problem just started.
You said the Tstat works, you just changed it? is it opening fully?
Doug
Doug
If after you troubleshoot your problem it leads to your radiator this is the best place to go:
http://www.dewitts.com/collections/c...inum-radiators
Dennis
Dennis
Doug
Doug
The Tstat opens fully. Checked it in the kitchen first.
Good input Doug. Thanks
This may sound off the wall, since you've stated that you are running a #'s matching 327/365 engine, but, have you checked the block to make sure it is a 3782870 and not a 3858180. The 8180's were used in conjunction with the 2870's, but, had much thinner cylinder walls. If the overbore of .060" is done on an 8180, I'd be a little worried. Just a thought.
If you could post a few pics of your engine bay so we all could see your set up that could help. Do you still have the fan shroud and the seals for example. Is the fan correct or some aftermarket flex fan? Original distributor with full time ported vacuum? Just a few more specifics and we should be able to narrow this down a bit.
Dennis
Dennis
Possibly a head gasket leak or cracked head. A block tester kit will verify if so, many shops offer this service, shouldn't cost too much, ot just buy your own, they are not expensive.
I would eliminate combustion gasses into the coolant first, then investigate things like water pump. The 16# cap is a combustion gas clue.
You can also leave the cap on loose (first notch) and drive the car and see if problem continues, releasing the gases into the air should slow or eliminate teh overheating, especially if you have a 160* Tstat.
Doug
Doug
Electric fan is just another fix to try and solve a different problem. You DON'T have an airflow problem, anything over 20 MPH, and you don't need a fan at all for cruise conditions.
Ah, the old meet at night trick. Kinda like the car is already warmed up when you get there to look at it trick. There is something being hidden, the question is, what?
Doug
Doug
Doug
Doug
Dennis
Dennis
Here are the only engine pics I have at this time:
#33
Doug
Doug
#35
Doug
#37
If I were the OP, I'd remove the Therm. and drive the car just to observe the result. Next I'd try filling threw the upper Radiator Hose and the Therm. Housing Port.. Never know, could be an Air Trap somewhere. (I know, highly unlikely). All Diagnosis Testing can be done with plain tap water for convenience. Keep us posted so we all learn something new. Al W.
#39
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
That said, you might want to run your hand all around the front of the core to ensure that the whole radiator is participating in cooling the engine.
Jim
#40
Kiss
Borrow a rad pressure tester and test the system for leaks . Check it cold first, then warm it up and pump it up again .
My guess would be a cracked head or a head gasket and
the pressure test will show you if it has either one .
Bill
Bill
