C1 wheel bearings observation.
I have had a set of tapered roller wheel bearing, in my trunk just in case kit, for 4 years. I didn't install the bearing because the old ***** were fine so why fix it if it isn't broke. Well, last Thursday my left front bearing went out so I replace both sides with the tapered bearing. What a difference these bearings made in the steering feel. If I had any idea how much improvement this change would make, I would have installed them the day I bought them. Just ordered another set for spares.
There are some mods on these cars that are just "must do" items if you drive them much....needle bearings are one, radial tires are another...
I bought the bearing from Allied Bearings in Los Angeles (310)837-0752 the inner bearing # is 909052R $26 the outer is 909067R $24 and the seal is 6064 $6. The bearings are made in Japan. Not U.S.A. made but at least not Chinese.
corvette central sells a front wheel roller bearing and seal kit #571043. to get the most satisfaction out of a c1 front end add the needle bearing king pin assemblies and radial tires.
Received 3,773 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Also, as mentioned, SOME people believe there is no change to handling between ball and roller bearings in the same car. I for one, feel there is an improvement in tracking---------------BUT AS I'VE MENTIONED SEVERAL TIMES RIGHT HERE, YOU GOTTA DO ALL THE OTHER STUFF TO THESE OLD FRONTENDS TO ACHIEVE THE OPTIMUM DRIVING/HANDLING RESULTS. This includes a properly rebuilt frontend (if needed) with alignment, proper adjustment of the steering box per the ST12 (and a rebuild if needed), replacement of the bearing in the center steering arm (if needed), roller bearings and radial tires. Wide wheels and tires LOOK cool, but excess width will subtract from ideal handling. For performance driving, the addition of the fast steering adapter to the center steering arm is helpful, but NOT such a great idea for daily street driving. I have one on the 56, and I'm the first to admit that it does stiffen up the steering when not moving or when moving VERY slowly. Once over 10-15mph, it isn't noticeable.
Also, as pointed out above, the roller bearings ARE NOT, repeat, ARE NOT available from ANY of the common American bearing sources (BCA, Timken, SKF, etc, etc, etc). Again, NOT available. The ONLY source for the roller bearings is offshore. And that brings us to the last part. For those Corvette owners who thrive on bragging about how much money they spend on their cars (and those people are prevelant!!!), then the bearings are readily available from the normal Corvette vendors at premium prices (CC, Paragon, etc). But if you want to acquire the EXACT SAME bearing, at the best prices, buy them from Allied Bearing in Los Angeles-------------------and of course, ALWAYS ask for the "Corvette club" discount. Which Corvette club??? ANY Corvette club, NCCC, NCRS, SACC, whatever.
You can thank Roy for the original information on the roller bearings!
Tom Parsons
St. Jude Donor '07
Some insist on power steering and A/C. I don't miss power steering at all but living in Orlando...I fully understand the desire for A/C. Disk brakes add a comfort and safety factor.
Some are adamant about dual master cylinders. Personally, I don't count that as a "must have"...some do however.
The ONE thing that I haven't done to the 56, and it is the ONLY thing I'd consider, is to add AC. Summers in Okla, ESPECIALLY this year, can be brutal!!! The number of 100+deg temps this year in Okla was record setting. There were even some days when my 51 Chevy's cooling system struggled to stay in an acceptable range with the AC on (stock radiator, 5-blade fan and no fan shroud.
Yesterday, working on the A26 in the hanger, was another scorching day-----------brutal. Today it was supposed to cool down--------------and boy did it! Today was a great welcome! I don't know if it even got up to 80deg by mid afternoon.
Tom Parsons
Tom Parsons
Jeff
Received 1,859 Likes
GM (Delco Moraine), casting #5456022 (with the "022" characters in a larger font size than the 5456), with "5454480" and "320-G" stamped into the steel plug in the front of the reservoir.
