Sponsored by: DashLynx
how do you mount tweets in a A pillars?
Old 11-01-2006, 02:27 PM
0TheRadioFlyer97
Former Vendor
TheRadioFlyer97's Avatar
St. Jude Donor '08
Default how do you mount tweets in a A pillars?
the A-pillar seems to be a popular way to mount tweeters to keep the sound stage high and in front. How do you go about mounting them where they don't stick out?
Old 11-02-2006, 10:39 PM
GeorgeB
Support Corvetteforum!
GeorgeB's Avatar
This is the response I got from member Darion:
All I did was take the flush mount holder from the kit and traced the opening size onto the pillar, I used a fine tip pen. Next I cut the material back that covers the pillar and removed it. Then I took my dremel tool with a bit that looks like a drill bit but is used for cutting, sorry I don't know the exact name, and opened up a rough hole. Looked up what I used on dremel web page, http://www.dremel.com/en-us/attachme...188549&G=66357 , that should help. Next I used a sanding stone to smooth and fine tune the opening size to get the fit I wanted.
Look above under "Sticky: What do you run in your system?" post #10
Old 11-07-2006, 10:13 AM
mykvr6
mykvr6's Avatar
you can do that. if you want something more custom looking you can also have them molded in.
like this:
or also something like this with a custom made grille.
the vinyl and grille in the above pic are black, the flash just lit them up a bit where they look lighter and you can see through the grille cloth a bit. In normal lighting it looks all black and factory. Just another option for a clean custom looking install of tweeters in the pillars.
Old 11-07-2006, 11:17 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
i like the top one in the large picture, how do you do that? is there a tutorial avalible?
Old 11-07-2006, 09:40 PM
VenkmanP
VenkmanP's Avatar
Is that a replacement panel or a modified factory panel?
If the latter, where can I get it done?
Old 11-08-2006, 11:31 AM
wiz1500
wiz1500's Avatar
This is a link to a good freind...
http://www.iniziale-designs.com/
They are the ones who help me do mying..
http://forums.corvetteforum.com/show....php?t=1373431
This is a link to my build.......
Let them no I sent you ( Keith with the yellow C-5) and they will take care of you...
Old 11-08-2006, 06:46 PM
VenkmanP
VenkmanP's Avatar
Thanks! Your pics clarified for me how that is done.
I was trying to figure out how somebody could modify the injection-molded plastic and have it look that clean... Cover it with vinyl, duh!
Old 11-08-2006, 10:31 PM
wiz1500
wiz1500's Avatar
If you have any questions feel free to ask....
To how do you mount tweets in a A pillars?
Quick Reply: how do you mount tweets in a A pillars?
