Pacific Northwest Idaho | Oregon | Washington | Hawaii | Alaska.
Differential Shop?
Old 04-01-2024, 10:55 AM
ccj
ccj's Avatar
Default Differential Shop?
Finished a track day yesterday in my C5Z and noticed on the drive home I have a loud howl on the freeway, increases under load, gone off-throttle. Shifts well, runs well, but with the ever present howl. Car has diff and tranny coolers but its possible the pump died (I know one of them was working b/c I could hear it when I turned on the switch).
Wondering if anyone has a recommendation to pull a differential/transaxle and potentially review and repair the diff/tranny cooler pumps/heat exchangers. ??
Thanks
Clarke
Old 04-01-2024, 12:33 PM
NW94Z
NW94Z's Avatar
There was a shop specializing in differentials in Kirkland but I recently learned they have closed.
I've recently diagnosed the diff as bad in my C5 Z as well. Similar howl to what you described. Speed related, becomes very clear at 29-30 MPH, disappears as soon as load is removed from the driveline.
Going to flush and replace fluid first then go from there. I've already begun to look at options to buy a new diff and swap them myself. Apparently the diff can be removed without dropping the entire driveline or even transmission.
Old 04-02-2024, 12:11 PM
ccj
ccj's Avatar
Looks like my friends shop is up for pulling the transaxle. But we are likely looking for someone to replace / rebuild the diff.
Old 04-02-2024, 01:46 PM
NW94Z
NW94Z's Avatar
Let me know if you find a reputable place to rebuild the diff.
Old 04-04-2024, 11:03 AM
billla
billla's Avatar
St. Jude Donor '14
https://www.kirklandtransmission.com/ would be my first call.
The following 2 users liked this post by billla:
ccj (04-04-2024), Fiberbundle (04-04-2024)
Old 05-09-2024, 07:00 PM
ccj
ccj's Avatar
Originally Posted by billla
Kirkland wasn't interested in doing a transaxle from my Z06. I did not have a conversation with them myself so it could be they don't like transaxles, corvettes or specifically track car stuff. Not sure.
Old 05-10-2024, 02:25 PM
billla
billla's Avatar
St. Jude Donor '14
Kinda surprised - not sure what "did not have a conversation with them myself" means, but I'd encourage you to call and talk to Tony directly.
On factor is that they only have one lift where they can drop the drivetrain out, so scheduling is a factor.
Old 05-10-2024, 02:59 PM
Michael Clemans
Michael Clemans's Avatar
GP Automotive is South Everett off 1238th close to I5. They repaired my drivers side differential on my C5 and did an awesome job.
https://gpautomotive.net/
Old 05-13-2024, 11:58 AM
ccj
ccj's Avatar
My friend's shop is pulling the transaxle. I have been waiting for lift space at his shop. He talked to Kirkland as they are nearby my friend shop.
Old 05-14-2024, 02:06 AM
CamarosRus
CamarosRus's Avatar
Call this company in Everett and ask their advice.................
https://www.yukongear.com/
Old 05-14-2024, 12:07 PM
billla
billla's Avatar
St. Jude Donor '14
Not too many shops are going to take on work like that - if there's an issue, then shop A points the finger at Shop B. So I can understand them taking a pass...
Old 05-16-2024, 01:18 PM
ccj
ccj's Avatar
That's how the national shops work that do transaxle rebuilds. Local shop pulls it and someone else rebuilds it. No different than a crate engine in that sense.
Old 05-17-2024, 11:40 AM
billla
billla's Avatar
St. Jude Donor '14
Sure; but there's a difference between buying a part and having local shop do piece part work.
Anyway, good luck - I hope you find someone to square it away for you.
Old 05-17-2024, 11:51 AM
ccj
ccj's Avatar
I get that. Dropping it off today. Expect transaxle will be out by the end of next week.
Old Yesterday, 12:55 PM
ccj
ccj's Avatar
Shop pulled the transaxle this week and dropped it off for rebuild. Shop owner said the fluid was very metallic, but that was no surprise based on how it sounded.
Old Yesterday, 01:13 PM
CamarosRus
CamarosRus's Avatar
What shop pulled the diff from Car and what Business is doing actual rebuild ???
Old Yesterday, 01:15 PM
ccj
ccj's Avatar
EVOMS (They actually a Porsche shop) in Kirkland, WA pulled the transaxle. The owner Sam is a friend of mine and did the head/cam/intake, momo steering wheel and some other stuff for me for a few years.
NW Differential in Monroe, WA is doing the rebuild.
Old Yesterday, 05:33 PM
NW94Z
NW94Z's Avatar
You don't by any chance know if NW Differential was located in Kirkland previously?
Old Yesterday, 07:54 PM
ccj
ccj's Avatar
Not that I know of. There is a shop near where Carb Connection is. They are the ones that Sam Stone at EVOMS went to talk to first. They were not interested in the work, but I don't know why.
To Differential Shop?
Quick Reply: Differential Shop?
