Took a ride today
Old 05-01-2024, 10:54 PM
dkleather
dkleather's Avatar
2016 C2 of the Year Finalist
Default Took a ride today
So I think I have a fuel pump failure again. The third time in six years! I’ve had two AirTec and now one AC fail in that time. The car has been flat bedded three times in the 25 years I’ve owned it and all due to the pumps failing.
Got to get her back on the road and open for suggestions of what brand you’ve had luck with. 327/300 engine.
Old 05-02-2024, 12:07 AM
reno stallion
reno stallion's Avatar
Received 1,536 Likes on 812 Posts
C2 of Year Finalist (appearance mods) 2019
Is your tank original ?
Old 05-02-2024, 06:17 AM
JF in MI
Pro Mechanic
JF in MI's Avatar
Received 1,324 Likes on 494 Posts
2023 C1 of the Year Finalist - Modified
BTDT
2nd time
dkleather (05-02-2024)
Old 05-02-2024, 06:29 AM
R66
R66's Avatar
Received 1,567 Likes on 1,054 Posts
When you remove the pump, is the spring and arm still intact and hard to push? Can you blow thru the pump at the outlet and get air out of the inlet?
Trying to diagnosis the failure of the pump with these simple tests.
Old 05-02-2024, 07:08 AM
DansYellow66
DansYellow66's Avatar
Received 2,645 Likes on 1,974 Posts
I hate that sort of thing, kind of ruins the day. Hope you can find a fuel pump to fix the issue once and for all time.
Old 05-02-2024, 07:11 AM
cwatson6
cwatson6's Avatar
Sorry that it keeps happening to you.
Old 05-02-2024, 07:39 AM
morly1963
morly1963's Avatar
I feel ur pain-good luck with ur problem.
Old 05-02-2024, 08:04 AM
dkleather
dkleather's Avatar
Yes. Clean and shiny inside.
Old 05-02-2024, 08:05 AM
dkleather
dkleather's Avatar
Originally Posted by JF in MI
BTDT
2nd time
Fuel pump both times?
Old 05-02-2024, 08:18 AM
dkleather
dkleather's Avatar
I don’t have the pump off yet. It broke down last evening in the middle of a busy three lane intersection and I was in no mood to check much when I got it home. Three strangers eventually pushed me into a parking lot. Blessings to them!
I did disconnect the fuel line, crank and had some gas come out but not much. I’ll check the tank sock and rubber hoses before I start on the pump but with my history with pumps and the fact the fuel hose at the inlet is only two years old, I’m betting on the pump.
The first AirTec had the arm pin move out that messed up the spring and arm. The second, which was a warranty replacement btw, went out because the inside valves weren’t staked and one fell out! I have a warranty replacement sitting in my basement that I didn’t use from that incident. I changed brands to AC and now this.
Old 05-02-2024, 08:36 AM
Fatdaddy
Fatdaddy's Avatar
I went through 3 pumps in 6 months last one I got 12 miles out of it. I gave in and went to electric 2 years ago so far no problem
Old 05-02-2024, 08:39 AM
JF in MI
Pro Mechanic
JF in MI's Avatar
No, in my case mine was an inop fuelie that I converted to electronic (electric fuel pump). The computer I used was a reman. In a case like mine this reman core had an intermittent problem where it would die after a long time running (getting warm I assume) which probably wasn't long enough to not pass the test and inspection. After getting a flat bed ride home twice I got suspicious and started carrying a spare computer. Next time it died I just plugged in the spare to drive home which confirmed the problem.
Old 05-02-2024, 08:45 AM
JF in MI
Pro Mechanic
JF in MI's Avatar
This is also why I posted in another thread (....your ride along tool kit) my main tool is a cell phone with the business card of the local towing service.
Casper001 (05-03-2024)
Old 05-02-2024, 09:08 AM
dkleather
dkleather's Avatar
Mine too. I sat in the middle of three lanes dialing up my saved AAA number. Gave them the information of where I was and I needed a flatbed. Three guys had parked in a nearby Red Lobster parking lot and worked their way through the traffic to get to me. They then pushed me into the lot to wait and stayed awhile.
Every time I’ve broken down there has been help from strangers to get the car to a safer area. I have done the same. I’ve even loaned my tools and help to a vintage Mustang owner to get it going again! 😂
This old car stuff is a brotherhood of sorts for sure.
The following 3 users liked this post by dkleather:
henry63 (05-02-2024), JF in MI (05-02-2024), ptjsk (05-03-2024)
Old 05-02-2024, 09:28 AM
Dreaming60’s
Dreaming60’s's Avatar
C1 of Year Finalist (appearance mods) 2019
This is not the answer for the poor quality of pumps and many replacement parts we get today, but I remember back in the early 70's, I had a fuel pump failure in my 1st 62 and installed one of those pulse electric fuel pumps and bypassed the mechanical pump completely. At that time I didn't want to open Pandora's box by swapping out the mechanical pump and possibly running into other problems, as it was my daily driver and I didn't have the money to pay a shop to do it.
Thinking about it, would an electric fuel pump solve some of the issues with the high evaporation rate of fuel in our carburetors today? I can remember hitting the key and hearing the pump run rapidly for a second or two and then stop once fuel was in the carburetor. Seems that would help for evaporation too. I was reminded of our "today" fuel issue just this week, as I started the 62 after 3-4 months and it took (five) 2-3 second cranks of the starter before the engine came to life.
Old 05-02-2024, 08:06 PM
tuxnharley
tuxnharley's Avatar
Received 1,956 Likes on 1,194 Posts
I went with a Holley high performance mechanical pump after a couple pumps failed when the lever arm pivot rod failed by wearing thru the pump body. The Holley pump has benn in there about 10 years now with zero problems.
dkleather (05-03-2024)
Old Yesterday, 05:38 AM
dkleather
dkleather's Avatar
Just an update on my problem break down. It was another fuel pump failure. I took it off and then apart and found the whole bottom of the pump under the diaphragm filled with gas. I don’t know how the pump actually works mechanically but I’m guessing the diaphragm had no way to function if it was trapped between two layers of gas. I didn’t find any tear or hole in it.
Anyway, I’m back on the road again. Hoping for the best….
Dave
capevettes (Yesterday)
Old Yesterday, 09:44 AM
Redbird
Redbird's Avatar
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
Try and find a good original AC pump to rebuild correctly. Check the fuel pump rod that goes to the cam as well.
dkleather (Yesterday)
To Took a ride today
Quick Reply: Took a ride today
