Looking for instructions for Lowering without cutting Bushings
St. Jude Donor '05
Looking for instructions re. lowering (NOW WITH A PIC of "After")
I am Looking for instructions for Lowering the c5 without cutting any Bushings. I saw it here a couple weeks ago but I can not find it... Any help would be greatly appreciated.
Thanks.
Thanks.
St. Jude Donor '03-'05-'06-'07
Boy that was quick Ed!! You must have some sort of alerting software
that lets you know when someone post a new thread asking for help on
the forum...
Juusssst kidding! I used those very images when I lowered mine!
the forum...
Location: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Patches-Excellent illustrations. Are there any issues to be concerned with other than a stiffer ride when doing this. Thanks.
Originally Posted by XCESIVE
how far of a drop will this be by not cutting anything and how much by cutting the rear bushings?...do you cut any of the front bushings also when you cut the back?
If you're looking for more of a drop, you can cut 1 or 2 bushing sections up front and get longer 6.5" or 7" bolts for the rear. No need to cut rear bushings - just get longer bolts. Remember that you need to clear speed bumps and other obstacles. Drop it on the stock bolt travel first and try it for awhile before lowering it further. Finally, do forget to get a 4-wheel alignment once you're satisfied with the ride height.
St. Jude Donor '05-'08
Originally Posted by Target Chaser
Patches-Excellent illustrations. Are there any issues to be concerned with other than a stifffer ride when doing this. Thanks.
Plus you can't run over a soda can in the street any more because you will hit it (he he he)...
I used the pics posted by Patches and they helped a ton. Remember though they are pictures after the work is done.
Originally Posted by 00hotvette
Q once you have droped the car on stock bolts how much weight can you have in the car? I would love to do this mod. Sticker in the door says 399lbs
Received 3,813 Likes
St. Jude Donor '03-'04
This Patches guy is some smart cookie
Originally Posted by Wicked Weasel
I am not sure if the weight limit would change - Gee 399 is already a low number - good thing for me my wife weighs 100 lbs otherwise someone would be sitting at home on nice vette days....
MONARTOR
Originally Posted by JACKAL0PE
Gotta get it aligned after you do it. Wait about 100 miles and let it "settle" before getting the alignment.
Originally Posted by madeouttaglass
Hmmmm... 399-100=
Funny - did we forget the golf clubs plus the beer cooler....
BTW - 239 and going down (thank goodness for racquetball 4xs per week) ...
Supporting Tuner
St. Jude Donor '05
Thanks all I lowered it last night and the difference "appears" minimal to me.... Though I measured it and it is an inch lower all around.... perhaps it was too dark for me to see it... or it was so dark that I accidently lowere the wifes Jeep.....
Seriously though I took it around the block afterwords and it it seemed the steering felt a little different.... perhaps quicker/tighter.... is it me?
You'll need to drive it for a week or two and allow the suspension to adjust and settle. It generally takes a good 100-200 miles. Then you can think about getting a 4-wheel alignment at a qualified shop that uses the latest Hunter alignment equipment.
Congrats on the lowering job.
