to fix the window push the button down and hold for 5 seconds and then pull it up and hold for 5 seconds
This forum is amazing! I just had this indexing problem, and this did the trick to fix it. Interestingly, this happened right after I did the CAGS mod, and had the battery disconnected. Is there is a connection, and if so, why? Is there anything else changed as a result of the battery being disconnected that I should know about? Again! Thanks to this wonderful place!
