Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
- Corvette C6 Corvette Secrets of the C6
Important information to help you understand your Corvette.
Secrets of the C6
Scissors you are the bomb!
I quite trying to program my garage door opener a long time ago, never could get the thing to take.
I am on my way to the garage NOW! Thanks again for the tip.
Just one question on headlights???
Originally Posted by Scissors
Okay, a long time ago I created a "Secrets of the C5" list.
Well it's time we get started on such a list for the C6.
This is a list of things which a lot of people don't know, regardless of whether or not they're in the manual.
Not just useful things, but also interesting things. For example, on the C5, we listed all of the locations of the chevy symbol. Please, add info to help the list grow.
-The C6 has front and rear brake cooling ducts beneath the car. They use high pressure areas to bring air to the low pressure areas where the brakes are.
-The button between the "1" and "2" buttons on the door is for easy exit/entry.
-The doors have a manual release located near the floor.
-The C6 can be entered by using the provided key in the lock above the rear license plate.
-The C6 can be started by placing the fob in the hidden receptacle in the glove box.
-The Automatic transmission has programming to hold gears while cornering.
-To get the dash to dim, you need to hold the dimmer switch in when rotated! The book does not tell you to push it in prior to rotation for the dimming. (thanks, shopman1)
-To get the garage door opener programmed when you have a variable code opener like Sears sells, you need to press the learn button on the unit then push the opener button in the C6 3 times for 2 seconds and it picks up the code. The book does not state that however if you go to the web site it will tell you how to address this problem. (thanks, shopman1)
-The holes on the inside surface of the exhaust tips are to eliminate high-RPM hiss.
-Turn the light switch one notch up from "auto" and then release to turn off the DRLs.
-Moving the turn signal lever part way and then releasing it will cause the lights to blink three times. This is for lane changes.
-To fully turn off traction control, you must press the button twice.
-If your window does not roll up or down that little bit at the top (indexing) then it may need to be set. This is explained in the user's manual, but involves holding the window down for 5 seconds using the switch and then holding it all the way to the top for 5 seconds using the switch.
I just want to make it like a regular car to turn on the headlights when I want to.
Is this possible? Or is it in the default?
Will any of this info work on the C-6 ?
Originally Posted by Tenderfoot
Here you go. May not be the complete list as C5 secrets thread was very long. Note, this list is for the C5 secrets:
Okay, I can think of the following "hidden features" that a lot of people don't seem to know about:
1. The little yellow "helper light" on the bottom of the rear-view mirror that illuminates the shifter area.
2. That you can put your key in the driver's door and turn it twice towards the front to unlock the passenger door and a third time to pop the trunk.
3. That you can pop the trunk and also pop the gas cap cover by pulling on metal lines hidden in the back.
4. That the little slotted cover on the dash behind the steering wheel is where the inside air temperature sensor is located.
5. All of the option codes are in the glove box. And if they aren't there, look on the underside of the rear compartment lid (passenger side, I think).
6. Tire inflation recommended pressures are on the driver's door (don't laugh, this comes up a lot).
7. The thing that looks like a little LED near the DIC buttons is a light sensor.
8. The thing that looks like a little LED near the defroster vent is a UV sensor for determining A/C usage to compensate for the heating effect of the sun.
9. Your build sheet is in the front re-bar, your front bumper cover must be pulled for access!
10. When the engine is shut off, you can get the odometer reading by turning on the parking lights.
11. You can program setting #3 (both memory buttons at once) in the seat memory to run the seat back and steering wheel forward for getting in/out of the car with the engine running.
12. Reset oil life by pumping gas pedal 3 times (but not with the engine running).
13. Hold down RESET button while on one of the trip odometers and it gives you the mileage you traveled since last starting the car.
14. Hold down the Active Handling button for 5 sec. to engage "Competitive Driving" (2000 and previous years must be stopped.)
15. If you hate DRLs you can pull the e-brake ONE click and they go off....
16. Simply remove fuse #2 under the hood and your DRLs will be out permanently. Only thing affected is that when you unlock at night using the key fob your front turn signal lights and back up lights will not flash. You front turn signals will operate normally. GO STEALTH and extend the life of your front turn signal bulbs (changing them out is not picnic).
17. The side-view mirrors can twist both forward and backward, decreasing the chance of damage if struck.
18. If you pull the seatbelts all the way out while you're buckled in, they ratchet back in to hold you tighter into the seat (that's how the owner's video describes this feature)
19. The parking brake is self-adjusting... but depends on the car rolling or wanting to roll backward to work. Not mentioned in the owners manual (looked for it).
20. I didn't realize there is a red LED light on the left side of the radio so I had one installed to work when the security system is on. Someone told me to program the radio theft lock feature and that initiated the LED flashing. Now I have two of them flashing when the security system is on.
21. There is a release opening with a flap to let air out of the car when the hatch is closed.
It is located just above the driver side rear compartment, behind the panel.
22. There is a spot on the driver side just out of the middle compartment under the carpet for the lug nut key. You should have a compartment on the drivers & passenger’s side (in the trunk) and a center compartment. On the left (drivers) side of the center compartment, on the left side where the center cover fits, there is an 'indent' that holds the wheel lock key.
23. The bolts that hold the disk changer in the car, when installed from the factory cannot be removed. They have to be cut off.
24. You can ground your amp to a screw/bolt that holds the rear middle compartment to the frame.
25. If you turn on the headlights, then go to parking light position quickly, the lamps remain up but the headlights are not burning - this is for washing the lights.
26. If you have a 6-speed car you can pop the trunk when the car is running by lifting the e-brake.
27. On my Z06, the interior illumination light (the light that shines down from the rear-view mirror) is blue-ish and it will turn to a yellow color by sliding a colored lens over the lamp opening (no sheezot!) - I am not sure why this happens but the light does illuminate the console/shifter area.
28. Also not listed here, but the good CorvetteForum folks schooled me on this - if you go to comp-mode on the DIC, you can just hit reset to go back to displaying whatever mode you were in (fuel, odom etc.) and the comp-mode will still be activated.
29. If you have the passive entry feature: If you lock your keys in the car, wait a few minutes and then shake the car. That will unlock the car.
30. HUD has a shift light for manuals.
31. You can easily shift the M6 trans up or down without the clutch if you match revs. (Not great for longevity, however.)
32. You can eject the CD from the in-dash player without turning on any power. Don't even need key in the ignition.
33. The cruise will disengage if you purposely make sharp side to side turns while cruising at say 60-80 mph.
34. When the engine is shut off, you can get the odometer reading by turning on the parking lights.
35. HUD has a shift light for A4's too... it comes on during a WOT run just before it shifts!
36. With the engine off, opening the glovebox automatically turns on interior lighting.
37. You have 20 minutes of auxillary power after shutting the car off.
38. There a key combination that can get the DIC to show any codes the car has thrown without autotap, etc. That combination is as follows:
• Turn the ignition key to the ON position, but do not start the car.
• Clear any pre-set messages by pressing the RESET button.
• Hold the OPTIONS button down, and press the FUEL button 4 times. This will get you into the CODES section of the DIC. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. Any code that ends in H is a code that was registered previously but is no longer an issue.
• Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# CODES".
• To optionally reset the codes once in manual mode, press and hold RESET until it displays "NO CODES".
• Press OPTIONS button to go to the next module.
• For a list of codes, check here: http://corvetteactioncenter.com/kb/q....php?qstId=242
Again, the above list is for the C5 as a couple of members requested in this thread.
Is there a way to keep the headlights from coming on automatically in a dark garage?
To do it on the C5 required either wire work or fuse removal.
The C6 supposedly has a way to do it in the DIC.
I just want to make it so I can turn the headlights on when I want to. Is there any way to shut off the headlights from coming on automatically?
Originally Posted by LS WON
When leaving garage headlights automatically come on and then turn off when outside light is bright.
Thanks I will have to check into this further as I remember that the switch always
Originally Posted by SilverCoupe
Leave the light stalk set for "Parking lights" (before you start the engine), the one just below "AUTO". All lights except the headlights will come on in a darkened garage. The headlights will never flash or come on.
returned to the auto position.
Thanks for those tips. The other day my wife and I worked on setting up our garage door openers. We had to switch sides to make it easier for me to enter/exit the Vette. I found the directions very complicated. But I finally stumbled on a very easy way. She held the Homelink button down. I pressed the learn button in on the garage unit, waited till the tiny light next to the learn button came on and then pressed the learn button again and heard a click. Told her to release the Homelink and presto, button programmed. Ours is a Sears garage door opener.
LS-WON - that was basically my question - are all the C5 secrets transferable to the C6?
I'm not sure if they are or not, but would like to know.
Has anyone started a C6 secrets list other than the Scissors thread?
