site change
St. Jude Donor '22
site change
site graphic sizing has changed and the tree listing under last post has been removed.
i logged out and in and the trouble is still there.
link tree that allows clicking on last entry to return
to sub forum is needed.
Change it back to what was working. This looks horrible and is less user friendly.
Put the tree listing back under the last post. Why does this get removed with almost every major change?
Making CFOT Great Again
If anyone at IB cares, the smilie dialog is still effed up on Android mobile.
I don't think the site graphic sizing has changed, but please provide an example so I can verify. What did change was some added padding. Aside from the breadcrumb missing at the bottom, is there a technical issue with the change?
Ready, Fire......Aim!!!!!
And now, where's the option to change the text size? Good going IB, you implemented a "fix" before even bothering to test anything.
They may, but I don't think they get the members involved. Guess the "Steering Committee" forum isn't relevant to this sort of change. Might have been a good idea for IB staff to give us a heads up in that section and even provide some samples of what the change would look like and why it's better. Seems to me that's what was done when I worked in an IT section......
Received 2,362 Likes
Did you add, or remove, padding?
The menu appearance in the post & reply to post is now the more brief Android style menu, that will take time to become familiar.
The removal of YT and other link buttons needs to be reconsidered.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,830 Likes
2015 C7 of the Year Finalist
Community choice has been blown away also. I see this
Community
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Community
Corvette Store
Wheels & Tires
Sponsored Ads
Received 2,827 Likes
Crowd Plow For Now
I tried to do a "cut and paste", in order to quote and discuss two similar posts, in a topic. I can't, unless I do something with "clipboard". The last time I researched this clipboard deal, what I found is that A) it isn't compatible with Win10, supposedly, and B) I haven't got a &^%$!!@ clue how to use this clipboard deal, even if it does work with Win10.
As others have already commented, it appears that something that wasn't broken, has been "fixed"...………...
Community
Corvette Store
Wheels & Tires
Sponsored Ads
Community
Corvette Store
Wheels & Tires
Sponsored Ads
If you're referring to the ability for you to change text size for your own replies, that option is still available.
Any guidance from the IB staff would be appreciated. The prior layout was much more intuitive. Thanks.
Thank you for making everything a lot easier to read.. i appreciate the new look !!!
