Vacuum Source for Cruise Control 95
Having trouble locating the vacuum source for the cruise control. My book shows it going to a source, but so far no luck chasing it back. All I have is an open tube that looks like it was broken off. I replaced the line from the tee to the cruize control and a portion of the line to the switch, but without a source plug in the cruise control will not operate.
Any help will be appreciated.
Thanks
Thanks
Thanks
Thanks
Jake
Asked for help-got answer
I found the vacuum source on the right side of the intake manifold, could not find the tube in the wiring harness so took the harness apart above the brake booster and found the vacuum tube. Cut it there and routed a hose over to the tee near the fuse block on the wheel well. Cruise control works just fine now.
Thanks Jake
Thanks Jake
The source is under the cover on the right side of the engine. there is a two connection plastic piece there that provides the vacuum for the cruise and the A/C control. These break with age.
If you don't plug the source for the cruise, you will be sucking air in the broken part.
bill
bill
