LED "halo" modification?
Former Vendor
St. Jude Donor '08
I'm thinking modifying my Halos after seeing pictures of the 09 camero concept:
Before:
Possible "after" pic (photohack) the halo rings would be at full brightness
My question is: Has anyone dared to take apart their halos to get a good look at the guts?
Before:
I have Halos - and the part that you are looking at modifying is the part that flashes with the turnsignals and gets brighter with the application of the brakes. The halo is "static" and only active with the lights on.
Just thought I'd mention that - good luck with your project....and no I have not dissected my halos.
St. Jude Donor '06-'07-'08-'09
Hey George, the Halo Bars are only lighted by 4 of the 32 LEDs in the unit. You won't be able to get the 4 LEDs that light the Halo Bars bright enough. It's also not a dual circuit running to the Halo Bars, so you wouldn't have high & low intensity for brake lights. Without entirely redesigning the light, it won't work buddy.
Richard
Richard
Former Vendor
St. Jude Donor '08
Richard
Richard
Received 19,523 Likes
'20-'21-'22-'23-'24
Have not modified my halo taillights. Sure would hate to mess them up.
Richard
Former Vendor
St. Jude Donor '08
CHAPTER 547. VEHICLE EQUIPMENT Subchapter "E" § 547.322.)
quote:
(d) A taillamp shall emit a red light plainly visible at a
distance of 1,000 feet from the rear of the vehicle.
With halos this shouldn't be a problem, however I will obviously test them prior to use. The stoplamp brightness output should not be affected.
Former Vendor
St. Jude Donor '08
Okay, Taking them apart isn't as difficult as I'd thought and i'm pretty close to having a wiring diagram figured out. I thought I was going to need polarized diodes but i may not.
Here's the halo with the back plate removed:
As you can see it's mostly a circuitboard for the Chip-style LEDs. The Halo LEDs are on the sides and are run off of what appears to be a seperate circuit.
here it is during testing:
Here's the critical section:
As you can see there are 4 wires that go to the Halo ring: red, orange, yellow and black. I measured the voltage on the red and orange wires to be 4.8v and 2.6 volts respectively with the running lights on. There appeared to be no fluctuation with either of these with the hazard lights flashing so i believe these to be a deticated circuit for the Halo rings.
The plan is to disconnect the running light (+) wire from the inner halo section, install the appropriate resistor and wire them exclusively to the halo ring. It sounds easy however i'm having a hard time determining which of the colored wires is the halo ring's positive.
Night Owl for life
Received 3,277 Likes
