Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
- C6 Corvette: How to Replace Your Power Window Indexing
Step by step instructions for do-it-yourselfers..
EI08034 — Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Conti
Cruise-in I Veteran
Cruise-in II Veteran
Cruise-In III Veteran
EI08034 — Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Continuous Up and Down (Diagnose Door Handle Switch, Replace if Necessary)
Models: 2007-2008 Cadillac XLR
2007-2008 Chevrolet Corvette
________________________________________ ____________________________________
This bulletin is being updated to end the need for diagnostic information and to provide field fix information.
Please discard Corporate Bulletin Number 08-08-64-001 (Section 08 — Body and Accessories).
Condition
Some customers may bring their vehicles into the dealership for a concern relating to the operation of their power windows.
Correction
Diagnose the exterior door handle switch as a possible cause for this condition. If diagnosis confirms the condition is caused by the exterior door handle
switch, replace both driver and passenger switches. Be sure to mark which switch comes from the driver and passenger doors. Parts will be requested
back through the Warranty Parts Center return process.
Parts Information
Part Number Description
10446243 Front Side Door Handle Switch
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
N9588* Front Side Door Handle Switch — Replace (Both) 0.9 hr
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
Condition
Correction
Parts Information
Navigator
I'm having the same problem on my '08 convertible. It first happened about 6 months ago and this week it happens every time the passenger door is opened. It quits after about a dozen index cycles and when I put in in drive. I hope the door handle switch is the fix.
