Custom Billit Throttle Bodies!!!!
http://www.revxtreme.com/specials.htm
90mm $465.95
95mm $469.95
100mm $499.95
These are awesome, especially for the big cube builds.
Prices are for fly-by-wire models, call for F-body cable models.
90mm $465.95
95mm $469.95
100mm $499.95
Also, does the actuator mount on the driver's side, or passenger? I'm worried about clearence with the PS reservoir and the FAST manifold.
So, they don't work with the LS2 parts? Damn, I'll have to find a used TB to get those parts. Are all LS1-6s using the same actuator/TPSs?
Yes, it is designed to fit LS2 & FAST intakes & all you need to do is swap the acuator motor & the TPS from a stock LS1/LS6 intake.
