Does anyone know for sure if the rear on the Z06 and the C6 is any different??
I have been told by several that the rears are identical except the Z06 has a bigger cooler. Anyone know for sure????
Supporting Vendor
St. Jude Donor '09
Yes sir they are completely different. The Z06 uses a 9" Differential.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
262-510-7600
For service email:
http://www.getrag.de/308.1?criteria1...sse=0&x=18&y=7
The C6 uses a Model 625 rated at 1542 nm
The Z06 uses a Model 626 rated at 1808 nm
About 17% higher rating for the Z06
Cruise-In VII Veteran
Check the Getrag site.
Unless everything I have read is incorrect his is untrue. The Z06 has a larger output shaft from the trans than the base cars and they cant be swapped. If this is not right I look forward to receiving the correct information.
Former Vendor
True, the ZO6 main shaft is .055 larger in diameter. Whether this is the same on the 2007 model base car or not, I'm not sure. One side note of interest, C5 hardened output shafts will fit the ZO6 diff.
We have a new GM ZO6 diff with the hardened shafts, micropolished internals, blueprinted by RPM transmissions for sale in the ZO6 section if anybody needs one.
Ed
Ed
Supporting Vendor
St. Jude Donor '09
Here are the facts
In 2006, the TREMEC T56 Transmission for the Z06 got a one-piece countershaft for added durability; 32-spline output shaft was added for durability; rear extension housing bolt pattern change; DEXRON VI compatible;
The Z06 package came with a stronger single-piece countershaft, which replaced the two-piece countershaft. The Z06 uses the MM6 6 speed transmission, the Z51 C6 uses the MZ6 version of the 6 speed, with ratios from the M12 Cadillac CTS-V M12 tranny. These ratios are higher in first, second, and third gears than the MM6 Z06 tranny, and has a slighty lower-ratio fifth gear to increase top speed in fifth gear to 186 mph on the 400 HP LS2 C6.
The output shaft was enlarged to a 32-spline unit, which is more durable than the 27-spline unit used in the standard C6 Corvette applications. The rear differential was also increased in size from an 8.25 inch ring gear to a 9 inch ring gear and a larger pinion gear. The bias ratio on the limited-slip differential was increase to 2.5:1 from the C6's 2:1 ratio, and the rear end side-cover mounting arms were made stiffer as well.
In mid 2006, the six speeds came filled with DEXRON VI, which was developed to behave more consistently during temp variations, and provide even lubrication in the tranny.
In 2007, the C6 may have adopted some of the changes, but I doubt that the ring and pinion were upgraded to the Z06 level.
Now if someone could come up with stronger CV joints made of 300M or DVR forged steel, we might be able to launch the Z06 without breaking the CV joints. So far, the fix is to retro the parts back to C5 era parts, which makes absolutely no sense to me whatsoever.
Jim Hall
Jim Hall
Former Vendor
Jim Hall
Jim Hall
Supporting Vendor
St. Jude Donor '09
BTW. I have synchro problems; just took my Z06 in for the roof and brake pad recall, and mentioned it to the SM. Do you think the earlier 06s using DEXTRON III might be the problem? Could the DEXTRON VI be the simple fix, or a trip to your shop?
Collections Hold
This is good.....
BTW~ Someone PM'd us to reply to this; however, we're not interested in commenting on this subject with the correct information, because everytime we do, we get butchered for it for trying to help, by the "internet experts" that come out of the wood-work. No more......
We will say that our HD cast iron differential case is unitized in design that it encompasses *ALL* differential models from 1997-2007, regardless of design, equipment, vehicle platform or otherwise.
Supporting Vendor
St. Jude Donor '09
Without comment, here is where we got our facts:
http://www.bluedevilvette.com/Trans_rearendinfo.pdf
Collections Hold
We're certainly not trying to discredit you directly Jim by any means, (heck, we use YOUR air-intake products) however, it's not uncommon for those press releases to contain inaccurate, miss-leading information- especialy when actual production parts undergo a design change from when the original press release was first issued.
We can tell you with 100% accuracy from direct, hand-on experience from building these C5/C6 differentials everyday for a multitude of performance applications for many tuners/installers/warehouses/racers all across the USA- some of the information in that press release, as well as most of the info in this thread (and on the internet in general) are dead wrong....period.
We've tried to come on here and provide others with qualified, credible information in the past as a customer service courtesy, so everyone would better understand what model had what, but everytime we've done so, we have gotton ridiculed/butchered for no reason time-and-time again for whatever reason by other "internet experts" that claim to know our product better than we do, despite our in-depth engineering knowledge of the products we make a successful living at producing/building/manufacturing everyday. That gets old after a while and we no longer have any use for internet debates from "internet experts" that have no credibility of direct, hands-on knowledge of the issue to even be there in the first place. Often times, those unconstructive internet debates foster anger and frustration amoung a larger group of folks trying to actually learn and then no one benefits from anything.
Of course, there are many folks that actually do contribute a wealth of good information on the internet on a variety of topics and they present that info with professionalism; therefore, they are heard and respected. However, those kind of folks are few and far between unfortunately and the internet becomes a deep sounce of overwhelming B.S. overall, rather than the converse.
I'm sure you know what I mean Jim, as you've had to fight a few internet battles yourself over you products over the years from what I've seen. That's ok though, as your obvious success of your business suggests that you know your product better than anyone else and you keep doing what you do to maintain that success. The same goes for us here.
Sorry for the long-winded read, but I'm very passionate about what we do here and feel very strongly about the the issue.... Have a great day!
Best Regards,
Phil- DTE
Best Regards,
Phil- DTE
Some of us are not experts, would like to know the truth, and hate being misinformed. I understand and appreciate your position but you have achieved nothing here other than to vent your frustrations.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
So, Phil DTE, what is the answer? I see too many answers in here and if you take them apart and can count to 32, you should be able to give the skinny. Do I need to search and find that this has been answered elsewehere on the site?
TIA,
Elmer
TIA,
Elmer
