Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- How to Replace Thermostat
Step by step instructions for do-it-yourselfers.
How do you install a 160 Thermostat?
I recently bought one, but it did not come with instructions. If anybody has an idea please forward your no how. Thanks in advance.
11 Ft. Lbs
Use a torque wrench that measures in inch pounds. 132 In lbs = 11 Ft. lbs. Make sure to use a drop of Lock Tite BLUE. It lubricates the threads to assure more accurate torque readings and keeps the bolts tight. Bolt to thread friction is not torque. Bolt stretch is the desired function of applied torque to a bolt. If everything is not clean and friction free then the actual bolt stretch at a 132 In. lb reading will not be accurate. 11 Ft. lbs is not much. This is way more **** than what is required for a thermostat housing but it is how it is done properly.
Originally Posted by drfeelgood
Where is the coolant drain spigot and what is the best way to get to it?
Thanks
John
Thanks
John
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by beezeye
I'll bite.
Uh......with a torque wrench?
Bob
Standin' by for the punch line!
Bob
Originally Posted by MSammet
I use that little spring loaded gizmo in my tackle box. What the heck, it's calibrated in lbs.
Originally Posted by shopdog
Wait until the engine is cold. Drain coolant. Remove the two bolts holding the thermostat housing. Remove housing. Pop out thermostat and O-ring. Install new thermostat, new O-ring, then reinstall the thermostat housing and tighten the 2 bolts to 11 ft-lb. Refill with coolant.
St. Jude Donor '09-'10-'11
Setting the PCM
After installing the 160* Stat, it IS necessary to reset the ECM correctly, or no difference will be noticed. The stock Stat is 192* which is significantly different. Once the ECM has been reset for 160, the fans will be set accordingly, and you'll run cooler. There are several other ways to complement the cooler running engine, but the 160* Stat, properly set-up, will make a difference.
BTW, the proper terminology is ECM, and it does NOT involve a full tune.
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,426 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Make sure the tab on the gasket mates with the notch in the housing or it will leak. Trust me.
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
You will notice a reduced temp at cruise- about 180 degrees. In traffic, the temp will rise as with the oem stat before the fan kicks on but since you are starting from a lower temp, it will take longer.
A reset of the fan turn on temps will be required to keep the temp lower in heavy bumper to bumper traffic, however.
Go Canes!
Wrong.
in the summer months your fans will run all the time with a 160...you must re-program/ if that helps.
Wrong.
I have Just a 160* in our '09 and '02. Work just as they should with No re-program. Not necessary. Cruise temp at 172-178*.
Fans work Exactly as before when engine heat goes up at idle.
