[ZR1] 21CMC ZR1 Heat Exchanger Pic
Premium Supporting Vendor
Just Arrived, we will be putting the car back together and reporting the results soon.
Twenty First Century Muscle Cars
ZR1 Heat Exchanger
60-65% more efficient than stock
Direct fit / Easy installation
Suggested for increased boost or power levels on the LS9
Pre-orders / available to ship in 10 days
965. + freight
[IMG][/IMG]
Best Regards,
John Page
972-417-7177
jpage@21stcenturymusclecars.com
ZR1 Heat Exchanger
965. + freight
[IMG][/IMG]
Best Regards,
John Page
972-417-7177
Anything that cools the intake charge an additional 65% is going to be good for you. Additionally, it will keep ahead of the heat-soak curve much better than the OEM unit.
The entire intercooler system would need to be 65% more efficient.
What the benefits are will take some testing to determine...but bottom line it isn't a bad thing!
In other words if the heated fluid entering the heat exchanger leaves close to ambient then increasing the heat exchanger size will not make any difference.
ZR1 parked in the garage, or the guy who is going to track it?
1 Post
If the intake air temperature is cooled sufficiently for the stock boost level then using a larger heat exchanger does nothing but block the flow into the radiator.
bigger, car, corvette, difference, efficient, exchanger, exchangers, heat, heatexchanger, intercooler, make, nuts, pic, redvette, soak, system, zr1
