zo6 and convertible back body panels the same?
Hi guys I need a passenger rear fender ie. back panel
for my z06 and a guy here has them from his convertible
will they fit the z06?
The reason why I suspect they will is because a guy in Albuquerque converts Z06's to convertibles and uses all GM parts. You might call Garza & Garza http://www.garzaandgarzaautobody.com/ and ask.
They will work; I put a Vert on my FRC. Trim about 3/4 of an inch off the very upper front corner that curves under the roof line and slot the two forward bolt holes on the fender so they will slide under the two bolts under the roof.
