Slip fit rear bearings teardown and analysis
I've had both rear bearings fitted for slip on with no spacer for about 10 years now. I average 10 k miles a year so i'm guessing i've got over 100 k on this setup. The spindle looked fine. I ran my fingernail across the surface and found no ridge at all. The bearing shows some wear on the inside of the race. I don't know how much of that was due to the clearancing i did to get it to slip on the spindle. I just put it back together as is. I adjusted it for no detectable play and will motor on for another 100 k.
I can see obvious wear pattern on the inner spindle surface. While that is not excessive at this time, and because you service your bearings regularly, it probably will never be a problem. But if Joe Blow doesnt service that bearing and lets it slip excessively, it will fail, and be dangerous.
And as I've said before when the inner is slip fitted and the axle shears off (axle almost always shears at the end of splines) the axle and wheel will come out of the housing breaking the caliper off and most likely rip the fender off and whatever else comes with loosing a wheel. If your going fast lord help you !
If the inner is press fit and the axle shears off the axle and wheel remain.
I view it as a safety concern and would never do it to a customers car but have no problem with a racer or guy that works on his own car using slip fits. JMO.
Data from one vehicle does not alter history. Looks like you don't work the car very hard. Congrats on the bearings holding up well.
Hi
Why did you install the slip fit bearing without the bushing ?
It would help hold the bearings to avoid turning of the races.
Otherwise, impressive docu. Specially the amount of bearing usage.
Made in Japan bearings ?
Rgds. Günther
Rgds. Günther
Another way of looking at it is that 5 out of 6 people survive a round of Russian Roulette.
As one who has long had slip fits without issue, not that I don't value opinions, but I could more easily give weight to testimony from someone who has actually experienced a failure or loss of wheel as a direct result of having them. Then again, perhaps it's the quality of the spindles themselves which are as much a factor as anything...
Inspecting them is on my do list, while I'm at it. () And, yes, I'll post up if I find anything significant enough to warrant reporting.
TSW
edit - BTW, I've always used the spacers.
TSW
I'm a real fan of doing it just like this. The only thing i would do different is sand the spindle to make the fit rather than the inside race. And perhaps make it a very slight press fit rather than slip on.
The spacers are not parallel unless you get lucky with one. Gtr1999 has documented this many times. Guess what happens when you put 125 ft pounds of torque against the inner races on that spacer? Yep, they crack. The other thing that causes the inner race to crack is excessive press fit.
TSW
TSW
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I did my right side like that about 28 years ago. When I (later) did the left side I did it the full press method as I didn't have access to a lathe that time. I've put a boatload of track miles on the car since then, and neither side has given me any problems.
I was thinking i could carry a housing set up with bearings and slip fit spindle with me on long trips and just bolt it in. I guess the caliper bracket is captive so i won't be able to get that off with the press fit so i have to carry one of those with me as well.
