Front sway bar orientation
I have just started installing my front sway bar and noticed that there is a slight bend on both ends. I have looked through this site and others to confirm which way is up, but haven't found any good pics to confirm with. So is it correct in the picture or do I need to invert it?
I haven't fastened the end links till I get it on the ground.
Thanks for all suggestions!
attach the links to the lower A arm. Since you have no spring installed push the lower A arm up till it hits the bump stop. If the bar hits the frame it's upside down.
