Need help with 67 wiper switch/motor wiring
I'm getting around to knocking out the last of the "left over" stuff...you know, the things that did not work out after getting the car all back together and did not stop you from driving it. I used a Painless wiring harness and for the most part everything worked out great.......with the exception of the wiper system. Here's the deal....I have a wiring diagram for 67, but I can't really tell which wire goes on which post because I did not have the original harness to determine how they were orientated in the plug. I made up a diagram (see below) as to how I currently have it hooked up. Here is what I am getting for operation...
In the off position (all the way left) I have slow wipers.
In the slow position I have slow wipers.
In the fast position, the wipers turn off and park........
Can someone give me the wire colors (1967) and what post they are assigned to. I really don't want to start swapping around the wires and cooking a perfectly good wiper motor that was done by Dave Hackel.
Thanks in advance for your help!!
R/Jeff
R/Jeff
Received 1,859 Likes
Here's how the circuit works, and which contacts are grounded (through the switch body to the cluster) for each function:
Yellow & light blue grounded = low speed
Light blue only grounded = high speed
Dark blue grounded (push button) = washer pump
That tells me I have the dark blue and light blue wire reversed on my switch. Do you have a diagram of the wiper motor side?? If not, can you take a look at your 67 and tell me if the two prong plug has the brown wire on top with dark blue on bottom and what is the order of the wires front to back on the three prong flat plug that plugs in on the bottom of the motor .
As always, thanks a million John!!
R/Jeff
It appears that the orientation of the male terminals on your switch are different than the ones on my '66, but I believe the wiper motors are the same so this diagram should help.
Regarding the brown and dark blue wires that go to the washer pump, they can go on either terminal. They are just completing a circuit.
Thanks for the GREAT diagram!! Will swap my wires around and see what we get....hopefully not smoke!!
R/
Jeff
Ta - Da..................man, sure works better when you have it wired correctly! To think I managed to wire the entire car including all the fuel injection, AC, power windows, seats and a pile of other goodies and the dang wipers kick my butt
Thanks again JohnZ and Buns
R/
Jeff
R/
Jeff
65 wiper switch problem
May I get your help with a similar problem?
I can bench test my 65 wiper motor directly to the battery without the switch and it works fine. When I try to use the switch (I've tried a 67, a 64 plus a 66 Tempest switch) I can only get it to run in High! What the heck am I doing wrong? I find it hard to believe all 3 switches are defective. Please enlighten me. Thanks: *****:
R/Jeff
Already had to a couple of times. Wipers are not an issue when your to busy trying to keep the water on the OUTSIDE!! That's one of the things I need to relook this winter when I am doing some of the warranty repairs
R/Jeff
Joe
Found it!
For whatever reason, there is a tab sticking straight up (very inviting and begging for a connection) that is part of the center (possitive lead) of the 3 wire connector.
Don't know why its there but it's caused some hard head scratching.
Joe
Joe
As posted earlier I got my wipers to work with the help of the diagrams and guidance from this site. Thanks again y'all.
Now hears a head banger!
Whenever I start the car the wipers immediately come on high and I have to fiddle with the switch to turn them off?. Sounds like a defective switch to me but I was wondering if anyone else has had a similar problem.
Cures to those used parts on eBay. LOL
Thank you
Thank You, You helped me 8 years after posted
Hey guys I got a ? I just got this 66 last month and the window washer pump was gone.
I got all the parts to build it back ..
Thing is I'm not sure how the cap with the 3 nipples that the hoses connect to are orientated to the pump.. any photo would help .. I can't find any that show how it suppose
To bolt up for sure...
