Show car with a fine clear coat scratches?
Hey all, I have a 07 Z06 Victory red show car I bought 2 years ago. The paint is in exc condition but in the sunlight I can see some very light clear coat scratches here and there. I would like to remove those but don't want to do too much. I am buying a DA buffer and some polish. I tried "Scratch Out" from Auto zone but it did not do too much. After reading many of the threads here I am wondering if just a very fine polishing pad and polish will do the trick?
John Ulrich (03-05-2024)
Moderator
Received 3,763 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
Get some 3D ONE and a few orange pads maybe
John Ulrich (04-26-2024)
64drvr (04-29-2024)
FYR, Ive done M-100 with either Megs M-Fiber pads or Buff N Shine 50/50.....With overall Good Results
I'm still chasing some (not all over) FINE Scratches..............I have 3D One but havent used enough evidently.......
Ive been using SONAX Perfect Finish with Yellow Rupes Pad...........but I still dont know , what I dont know...........
Moderator
3D one products can be purchased at Autogeek and Amazon.. the pad depends on which machine you have
Doubtful. The clearcoat on Vettes is very hard. My friend's C6 Callaway had similar light scratches and swirls on it, and I had to 2-step correct the paint. I used Meguiar's microfiber cutting disks and M100 compound, then followed up with Lake Country microfiber polishing pads and Blackfire finishing polish. If you are lucky, your swirls are more superficial than his were. However, I honestly would go straight to Buff and Shine Uro-Fiber 50/50 pads and 3D One compound/polish. You may get lucky and be able to 1-step with that combo.
FYRARMS (03-18-2024)
KRS (03-18-2024)
mrg (04-10-2024)
KRS (03-18-2024)
KRS (03-18-2024)
KRS (04-26-2024)
CamarosRus (04-29-2024)
FYRARMS................You wrote " The clearcoat on Vettes is very hard. My friend's C6 Callaway had similar light scratches and swirls on it, and I had to 2-step correct the paint. I used Meguiar's microfiber cutting disks and M100 compound, then followed up with Lake Country microfiber polishing pads and Blackfire finishing polish. If you are lucky, your swirls are more superficial than his were. However, I honestly would go straight to Buff and Shine Uro-Fiber 50/50 pads and 3D One compound/polish. You may get lucky and be able to 1-step with that combo."
If I cant remove my FINE (Very intermintent) Scratches with Buff/Shine 50/50 and 3D, should I revert to M100 on a Meg's 3" M/Fibre Cutting Disc......
Do you have any fear of polishing thru (2012) Corvette Clear with M100 ????
I have a GRIOTS G9, Porter Cable and a Long Throw DA I dont use very often
Will SONAX Perfect Finish or Car Pro Reflect accomplish much if anything on Corvette Clear ????
Thanks
Thanks
