Vibrations in steering wheel running Pirelli scrubs
Hi, last month at Road Atlanta, with my C6Z, I was running my usual setup, forgestar with scrubs 305 and 315 on 18's
and by the end of second day I had alot off vibrations in the steering wheel, to a point of not feeling comfortable sending it at turn 12
The car checked fine, bearing and all fine, my personal guess is rubber pickup? Or ?
Thank you for shinning on my issue.
Have you carefully inspected each tire? Rubber pickup should be obvious but that's a condition that in my experience, only impacts cool-off laps and out laps, since the pickup rubber disperses once the tires are hot. I have made it a habit of thoroughly checking my tires after each session. The last time out I found a left front delaminating which went from looking great to what you see below in one 20 min session. The vibration brought me in early thankfully.
Adrien Marsoni (05-06-2024)
You could be spinning the tires on the wheels throwing the balances way off. I’ve had this happen and had to pack up early as I couldn’t get it figured out until I had the wheels and tires checked and re balanced
The following 2 users liked this post by Black E:
Adrien Marsoni (05-07-2024),
Poor-sha (05-18-2024)
Received 9,007 Likes
Bill
The following 2 users liked this post by Bill Dearborn:
Adrien Marsoni (05-15-2024),
NoMatter (05-15-2024)
Also make sure to balance the wheel alone, before the tire is mounted. I have done this on two different sets of wheels and have zero issues. Also when changing tires you just swap the rubber and no need to balance.
I don't bother balancing scrubs anymore. Between the built-up rubber that scrub tires are delivered with that will immediately wear off, and the fact that the tires move on the rims it's a worthless exercise. I have done as oh4GTO suggests and check rim only balance. We repair or discard any that are significantly out of balance. Even 200TW tires seem to move almost 1/4 rev on the front end.
You would think that as difficult as it is to seat the bead on Pirelli slicks they would not move on rims but they do. I've tried hair spray, and rims with knurled seating areas and nothing works.
Have I ever mounted a set for you? My tires never move unless I have to use trackside service travel racing. Hairspray always works for me but I also have bead sealer which is even stickier.
