Squeaking…
7th Gear
Squeaking…
I bought my C8 brand new a couple of months ago and now it’s making these weird squeaking noises from behind, what could it possibly be??? Anyone else experience this???
Can be heard @ 0:14, 0:16, 0:21, and 0:49
All I hear in the clip is the exhaust and tire/road noise. Perhaps you’re hearing the injectors, which sounds like a sewing machine…
vexeddonut (05-19-2024)
Received 5,298 Likes
I've seen a number of later Vettes' seat springs squeak once in a while.
My C7 had the same issue right off the truck. Drove me and the service tech nuts.
Then an old Corvette guy told us to use the silicone lube on all the weather stripping and violá... no more squeaking.
Coupe or HTC
The following 3 users liked this post by TopGunn:
7th Gear
7th Gear
Sounds like an easy fix
Cumbers (05-19-2024)
Any silicone lube on the rubber gaskets. (Doors, remove top, rear truck hatch)
Call me crazy but I have been using WD40 on my fan belts for 40 years. You can spray it on not running so it doesn't get blown all over.
Is the noise tied to the engine rpm or is it related to motion, bumps?
Good luck.
Good luck.
vexeddonut (05-20-2024)
I heard the squeak at the times indicated. Does not sound so much like the weatherstip squeak. What it does sound like is the occasional squeak my muffler cylinder deactivation exhaust flow control valves make when they transition between V4 and V8 mode. And also, with NPP, the tailpipe flow control valves will open and close depending on the Driver Mode and throttle demand. In Tour they are closed at idle an benign driving but twill open with spirited driving. With Sport the are open at idle and most driving scenarios. With Track they open nearly all the time. But even in Sport of Track, they will close at times to meet Federal Bypass Standard. The point is, those valves can open and close during normal driving, and if they squeak, which mine do from time to time. you can hear it.
I think you can test it (if you have NPP) Just sit in the driveway with the engine running and idling. Switch the drive mode between Tour and Sport. See if you hear the valves move or squeak. If you dont have NPP, the other AFM valves in the muffler could be the ones that squeak.
The following 2 users liked this post by Andybump:
Ron_Attleboro_MA (05-19-2024),
7th Gear
Good luck.
Good luck.
7th Gear
Andybump (05-20-2024)
