01 corvette crammed, headers high short term fuel trims
01 corvette cammed, headers high short term fuel trims
Just got the car running with long tubes, and a BTr stage 3 NA cam. Car has +28 short term fuel trims at idle, seem to drop down to around +7 with some rpm. Had the car tuned through mailordertuner. If I’m correct, that’s way to high isn’t it? Car runs ok, just smells really bad and burns my eyes. Worried about hurting the engine.
Last edited by Jmsomm; 05-07-2024 at 10:05 PM. Reason: Incorrect spelling in title
Need to have a tuner look at it to fix the airflow and/or fuel models to get things back in check. Wideband highly desired to dial in the PE (high load) operation as well.
Yes that quite high. Possibly running a little lean at idle if it's hitting the STFT limit. The smell and burning is just more a normal result of the cam though IMO.
I forget exactly the limits for the "system too lean" or too rich codes. But if the tune disables Long Term Fuel trims this may in effect disable that feature/diag trouble code from functioning right.
If it's a MAF or speed density tune, it's entirely possible for it to be really lean in one spot and fueling fine in another. Lot of guessing/speculating until we get some logs or read the PCM and see what's on it--> all goes back to taking it to a trusted tuner.
Can you log using HP Tuners? What are the STIT and LTIT values? (Long/short term idle trims) These will be in grams/second. It's an adjustment to the idle base running airflow value. If the net value of STIT + LTIT is a large number, you'll need to adjust your idle base running airflow.
What is the MAP reading during warm idle? You'll need to dial in the VE table. There are only a couple of cells in the VE table that will be in use once the engine is warm and idling. You can raise the VE value in those cells to bring the fuel trims down.
Finally, I would disable EVAP purge while tuning idle. This can be disabled in the special functions dialog under HP Tuners while the engine is running. When EVAP purges, it adds fuel to the intake and this affects this fuel trims. It's hard to get a good read on fuel trims when the EVAP purge is cycling on/off.
St. Jude Donor '12-'13-'14
You may have an unmeasured air leak. The car thinks its lean, and adding fuel.
if you changed injector, the data may not have been entered correctly
are the long term fuel trims on ?
long term fuel trims are off. Used a smoke machine and found zero vacuum leaks. Car is still on stock injectors. Got it out for a drive today and it runs great. Just rich at idle.
St. Jude Donor '13-'14-'15
I would be more concerned with the "long term fuel trims" and not the STFT's
At training we were taught not to look at the STFT's at all
+28 is a lean condition but you will only get a LEAN code if the LTFT's go beyond either plus or minus 25%
Agree I would check for a vacuum leak or a post MAF airbridge leak
