Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-11-2004, 09:42 PM   #1
Railfan
CF Senior Member
Railfan's Avatar
Default Does changing rim sizes create problems?
Currently, I have 17 and 18 inch rims and have been thinking about new rims, sizes 18 and 19 inches. Does the increased size of the rims cause any problems with brakes, speedometer, etc.?
Thanks.
Mike
Railfan is offline   Reply With Quote
Old 10-11-2004, 09:50 PM   #2
MYCoupe
CF Senior Member
MYCoupe's Avatar
As long as you keep the overall diameter of the tires the same, you shouldn't have any problems.
MYCoupe is offline   Reply With Quote
Old 10-12-2004, 11:14 AM   #3
shurite44
CF Senior Member
shurite44's Avatar
Send a message via Yahoo to shurite44
Default wheel change
The diameter of the wheel and the slope from front to back are the primary considerations. The front will accept at least a 285/30/18 with no rubbing and maybe larger. I know this size is good because I have that on by 03 coupe. The rear will accept at least a 315/30/18 with no problems, and I have seen up to 335/30/18 refered to on the forum with no tubbling. I have the 285/30/18 front and 315/30/18 rear, chrome C5 thin spokes from bobs house of wheels. Bob is a very good vendor I had the wheels within 1 week of placing my order. I have read you need a back to front slope for proper active handling function. The stock slope is .98th of an inch, I have .71th of an inch and everything seems to be working fine, at least no codes or lights. Here is a tire calculator that will give you comparative tire diameter on tires sizes.http://www.discounttire.com/dtc/broc...o/tireMath.jsp This will help you if you are just trying to match stock tire height or if you need to program (using something like a hypertech III), in your new tire heights. Good luck with your wheels
shurite44 is offline   Reply With Quote
Reload this Page Does changing rim sizes create problems?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
