Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-10-2004, 11:05 PM   #1
Rob4092xx
CF Senior Member
Rob4092xx's Avatar
Default Need wheel sensor modification info!
Will wheel sensors on wheels taken from a 2002 C5 work on a 2000 C5?
I know 2000 wheel sensors will not work on a 2002 DIC, but is the reverse the same?
I am purchasing some wheels and tires from a 2002 C5 and am hoping the wheel sensors will work on my 2000's DIC?????
I have heard the valve stem holes are different sizes. Is there a modification to make my 2000 sensors fit in the 2002 wheels?
How hard is it to break the side of the Run-Flat tires down to get to the sensors so I can switch them?
If they are different in size or weight, will the tire need to be re-balanced????
Can anyone provide me with the part information necessary to make the 2000 sensors fit into the 2002 valve stem holes?
Thanks!
Rob4092xx is offline   Reply With Quote
Old 10-11-2004, 02:43 AM   #2
wamara
CF Senior Member
Cruise-In II Veteran
wamara's Avatar
Rob, I do believe that the design of the sensor was changed beginning in the '01 model year, thus an '02 sensor will not function in an '00. The electronics are simply not compatible; it's not just the different valve stem grommets.... Sorry.
wamara is offline   Reply With Quote
Old 10-11-2004, 11:38 AM   #3
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Yup...........1997-2000 are the same.
Allthrottleandsomebottle is online now   Reply With Quote
Old 10-11-2004, 02:09 PM   #4
Rob4092xx
CF Senior Member
Rob4092xx's Avatar
That is what I figured....
Since I still have the 2000 wheels and sensors mounted in them, can I take the sensors out and re-mount them in my 2002 wheels?
In other words, will my 2000 sensors fit in my 2002 wheels or do I need to make some type of modification in the valve stem hole?
Old 10-11-2004, 06:27 PM   #5
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
EVIL_C5's Avatar
so 2004 sensors wont work on a 99?
EVIL_C5 is offline   Reply With Quote
Old 10-11-2004, 08:51 PM   #6
Corvette Poor
CF Senior Member
Corvette Poor's Avatar
1997 - 2000 sensors will ONLY work on those year cars
2001 - 2004 sensors will ONLY work on these year cars
Corvette Poor is offline   Reply With Quote
Old 10-12-2004, 07:43 AM   #7
Cruise-In V Veteran
NCM Ambassador
As far as I can tell ( didn't get ruler out) wheel dimensions for sensor mounting from 1997-2004 are the same. I have put 1997-2000 sensors on a 2001 wheel w/o issue.
The nut height is a little different between the 2 models sensors but does not effect mounting them
Old 10-12-2004, 01:23 PM   #8
Rob4092xx
CF Senior Member
Rob4092xx's Avatar
How about the difference in weight (was there any?)?
If there was, did you have to re-balance?
Old 10-13-2004, 07:46 AM   #9
Cruise-In V Veteran
NCM Ambassador
I had them swapped when I put tires on...........you could run them and see if you get any vibtation. Both sensors are light so it may be ok.
Reload this Page Need wheel sensor modification info!
Tags
modification, sensor, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
