Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-07-2004, 05:26 AM   #1
for yayo
CF Member
for yayo's Avatar
Default 275/40-17 on 9.5's all around
I have an 88 vette and I have 275/40-17 on 9.5's all around. Is that the stock tire sizes for my car or did the previous owner put bigger tires on the front? Would it be wise for me to put 255/40-17's on the front? Would those work on a 9.5? Whats the biggest tire I can fit on a 9.5?
Thanks,
Tony
for yayo is offline   Reply With Quote
Old 10-07-2004, 07:14 AM   #2
leadfoot4
CF Senior Member
leadfoot4's Avatar
One of my friends recently bought a 1990. I'm pretty sure that it has the 275s all around, also.
leadfoot4 is offline   Reply With Quote
Old 10-07-2004, 10:47 AM   #3
MYCoupe
CF Senior Member
MYCoupe's Avatar
Quote:
Thanks,
Tony
Those are the optional rims on the 88 and that is the correct tire size. They didn't put the 255/45/17 up front until 92 or 93, but that was on a 8.5" wide rim. Putting skinnier tires up front will help if your car "wanders" on the highway, but that is usually caused by the "truck ruts" or indentations in the roadway. You'll make your car more prone to understeering with the skinnier tires up front. Personally I wouldn't do it. I run 275/40/17 up front and it handles great. To answer your question, yes you can put 255 on 9.5" rims. The widest tire that you can run would be a 285/40/17. Hope this helps.
MYCoupe is offline   Reply With Quote
Old 10-07-2004, 10:51 AM   #4
c4cruiser
CF Senior Member
Support Corvetteforum!
c4cruiser's Avatar
17x9.5 wheels and 275/40-17 tires came with the optional Z51 or Z52 suspension package for the first time in 1988. Check your option sheet under the console lid for either of these codes. You may also find QA1 as a code that identifies that size wheel.
The standard wheel and tire for 88 was 16x8.5 wheels in a new design for 88 only and 255/50-16 tires.
Keep the size that you have now. There are a wide variety of performance tires available in that size and having the same size at all four corners allows you to rotate the tires for better wear. With the 9.5" wheels, the 275 tire fits the best although you can go to a 285/40 tire. A 255 tire is really designed for a 8.5" wheel width and it would be streching the tire to fit on the 9.5" wheel.
c4cruiser is offline   Reply With Quote
Reload this Page 275/40-17 on 9.5's all around
Tags
17x95, 2554017, 275, 95, corvette, fit, rim, tire
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
tires--- 275/40's on a '84?? radwebster C4 General Discussion 10 05-10-2003 11:31 AM
Any problem with TC/AH when running 18's all around on a C5? Patman36 Wheels & Tires 9 07-06-2002 03:23 AM
C4 Widest Tire (on 17 x 9.5) That Will Clear On The Front? vetluvr C4 Tech/Performance 10 01-14-2002 07:08 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
