Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-06-2004, 10:40 PM   #1
nolan1123
CF Member
nolan1123's Avatar
Default Widest Tires for my wheels?
hi there
I was wondering if anybody knows if i can put wider tires on my 1993 factory wheels
Original Equipment Front 255/45-17 8.5 inch wheel
Original Equipment Rear 285/40-17 9.5 inch wheel
What is the widest tires i can get for my wheels without hurting the car?
Any suggestions
thanks
Bruce
nolan1123 is offline   Reply With Quote
Old 10-07-2004, 01:37 AM   #2
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
Quote:
Originally Posted by nolan1123
hi there
Any suggestions
thanks
Bruce
If you obey the tire manufacturers' recommendations, then that's as wide as you can go. You can squeeze slightly bigger tires on those wheels (maybe as much as 275 front, 295 rear) but the tires will be operating in conditions that they aren't designed for.
Do a search this is a pretty well covered topic.
Vis Croceus is offline   Reply With Quote
Old 10-07-2004, 10:53 AM   #3
MYCoupe
CF Senior Member
MYCoupe's Avatar
I don't know of a wider tire that you can run out back because the next size that would work for you would be 315/35/17 and you need 17x11" rims for that.
I've heard of some people running 275/40/17 up front on the 17x8.5", but as steve9899 stated that is not the optimun rim size.
One idea is to but two other 17x9.5" rims to use up front and then run the 275/40/17 or you can upgrade your rims like I did
__________________
MYCoupe is offline   Reply With Quote
Reload this Page Wider Tires
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Performance of wider tires 03LingenfelterC5 C5 Tech 25 05-13-2002 04:28 PM
What improves braking more, Pads, wider tires, or Caliper/Disc combo?? MelloYellow C5 Tech 22 01-05-2002 12:51 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
