Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-25-2004, 06:49 PM   #1
SurfnSun
CF Senior Member
St. Jude Donor '10
SurfnSun's Avatar
Send a message via AIM to SurfnSun
Default How much is .7mm in wheel fitment?
I found a set of wheels pretty cheap to use as a back up...the bolt pattern is 5x120mm. The Vette is 5x120.7mm. How can I make these fit?
SurfnSun is offline   Reply With Quote
Old 10-01-2004, 06:23 PM   #2
Bobo16
Junior Member
Send a message via AIM to Bobo16
I don't think it will work. I think you need a more positive offset.
Bobo16 is offline   Reply With Quote
Old 10-02-2004, 08:26 PM   #3
MYCoupe
CF Senior Member
MYCoupe's Avatar
Quote:
These should fit. Bolt pattern has nothing to do with offset. I wouldn't worry about a .7mm difference in the bolt pattern. There is enough play within the stud holes to compensate for this small difference. 0.7mm is less than a 1/32" difference!
__________________
MYCoupe is offline   Reply With Quote
Reload this Page How much is .7mm in wheel fitment?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
