Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-11-2004, 12:05 PM   #1
brrymnvette
CF Senior Member
Default What kind of machines do they use to make wheels?
Do they CNC make them. Start with a chunk and cut out the rim? How do they do it and what kind of equipment do they use?
__________________
brrymnvette is offline   Reply With Quote
Old 09-14-2004, 10:44 AM   #2
rocco16
CF Senior Member
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
The short answer is "it depends".
Obviously, different type wheels require different processes and machinery. Are you talking about cast, forged, or multi-piece wheels?
Larry
rocco16 is offline   Reply With Quote
Old 10-29-2004, 01:52 PM   #3
brrymnvette
CF Senior Member
Larry
All 3? Which is the easiest to make? I guess multi would be the fastest because you can use any barrel with any center. What tyoe if machine do they use? Where so they the machines from?
Old 11-05-2004, 09:48 PM   #4
jfrc
CF Senior Member
jfrc's Avatar
Send a message via Yahoo to jfrc
saws-all, hand drill, and a file
__________________
If I had a small penis, this is where I would list all of my car's modifications.
My mind is a constant battlefield between and . . . . . . one side is winning
jfrc is offline   Reply With Quote
Old 11-06-2004, 11:32 AM   #5
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
The link below should help explain.....Seems I deal with this type stuff all the time I was looking for some old info & thought some folks would like to read a short article on makin some HRE rims!
http://forums.corvetteforum.com/show...hlight=HRE+545
Allthrottleandsomebottle is offline   Reply With Quote
Old 11-06-2004, 04:15 PM   #6
fcarga
CF Senior Member
thanks--an interesting read
fcarga is offline   Reply With Quote
Old 11-07-2004, 09:52 PM   #7
rocco16
CF Senior Member
rocco16's Avatar
Quote:
The easiest, or more correctly the fastest, to manufacture is the cast wheel: cast it in a mould, machine it (drill and lathe?) and paint/polish/clearcoat it.
The forged wheel adds the forging process(using a hammer forge) after the rough casting.
The mulit-piece is the most involved...that's why they cost 3 to 5 times more than cast. The centers are machined (CNC 3- or 5-axis mill)forgings, while the rims are spun on a spinning lathe. That is followed by the paint/polish/anodize/etc finish. Then they have to be assembled and sealed, usually by hand.
Some wheels also go thru some NDT process (non-destructive testing) such as X-ray, fluorescent penetrant, or eddy current, before they are packaged for shippment.
It helps to take a tour through one of the major manufacturers. I am lucky enough to live close to two of them, HRE and Kinesis, and was impressed by both of these and their willingness to 'show me around'.
Larry
code5coupe
Reload this Page What kind of machines do they use to make wheels?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Merlin777 – A Sneak Preview Merlin522 C3 Tech/Performance 80 07-12-2002 07:41 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
