Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-23-2004, 10:01 PM   #1
biggrizzly
CF Senior Member
Support Corvetteforum!
biggrizzly's Avatar
Default Best Tire Size for 17"X9.5" wheels on '94 coupe?
What is the best Tire Size for 17"X9.5" wheels on '94 coupe?
I have Potenza 275.40ZR17 now
[Modified by biggrizzly, 7:50 AM 5/24/2004]
biggrizzly is offline   Reply With Quote
Old 05-24-2004, 01:42 AM   #2
BAM92
CF Senior Member
BAM92's Avatar
Default Re: Best Tire Size for 17"X9.5" wheels on '94 coupe? (biggrizzly)
275/40/17 is probably best. 285/40 also fits very well but has a slightly taller side wall than the 275.
BAM92 is offline   Reply With Quote
Old 05-25-2004, 12:02 AM   #3
apollo30346
CF Senior Member
apollo30346's Avatar
Default Re: Best Tire Size for 17"X9.5" wheels on '94 coupe? (BAM92)
275-40-17 is the correct size....and the 285-40 is not taller it's more narrow......275=how wide the tire is so the bigger the number the wider it is and 40= milameters for the height of the sidewall.
apollo30346 is offline   Reply With Quote
Old 05-25-2004, 01:35 AM   #4
BAM92
CF Senior Member
BAM92's Avatar
Default Re: Best Tire Size for 17"X9.5" wheels on '94 coupe? (apollo30346)
40 is the aspect ratio. Meaning that the sidewall is 40% of the width. 40% of 285 is greater than 40% of 275. Therefore taller sidewall. As for the correct size, 88-92 had a 275 mounted on all four of the 9.5 inch wide wheels. 93-96 standard size came with a 285 mounted on the rear wheels which were also 9.5 inches wide and the fronts being only 8.5 inches wide came with 255's.
[Modified by BAM92, 12:38 AM 5/25/2004]
Old 05-31-2004, 12:03 AM   #5
rocco16
CF Senior Member
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Quote:
275-40-17 is the correct size....and the 285-40 is not taller it's more narrow.......
Actually, the 285 is both taller AND wider than a 275 of the same model tire.
Larry
code5coupe
rocco16 is offline   Reply With Quote
Reload this Page Best Tire Size for 17"X9.5" wheels on '94 coupe?
Tags
1994, corvette, coupe, size, tire
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
