Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-21-2004, 01:07 AM   #1
mountainbiker2
CF Senior Member
mountainbiker2's Avatar
Default Can you switch tires left to right?
I have Kumho MX tires. Seems like I do more right hand turns fast. The outside edge is wearing more then the lefts. So can I just switch sides? The Kumho mx would be running reverse now. I don't care about rain traction. Is the tire safe now running oppisite direction? The wheel sensors I would have to re-program. Thanks. Steve
mountainbiker2 is offline   Reply With Quote
Old 05-21-2004, 06:48 AM   #2
leadfoot4
CF Senior Member
leadfoot4's Avatar
Default Re: Can you switch tires left to right? (mountainbiker2)
Just my $0.02 worth.... You might be "safe", but I think that the performance would probably be compromised.
leadfoot4 is offline   Reply With Quote
Old 05-21-2004, 09:49 AM   #3
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
it would be fine in the dry but it would have serious issues in the wet when running in the wrong direction ...... the tread pattern is designed to pump water out from under the tires contact patch and when you reverse the pattern it will pull water under the tire causing the tire to hydroplane
Luke@tirerack is offline   Reply With Quote
Old 05-21-2004, 01:56 PM   #4
ST-rider
CF Senior Member
Default Re: Can you switch tires left to right? (Luke@tirerack)
what about dismounting the tires and remounting on the other side
so as not to change the direction?
ST-rider is offline   Reply With Quote
Old 05-22-2004, 11:07 AM   #5
mountainbiker2
CF Senior Member
Default Re: Can you switch tires left to right? (ST-rider)
Yes I can dismount them, but then I have to pay $80 for doing that. Thanks. Steve
Old 05-26-2004, 05:52 PM   #6
ArmyVette
CF Senior Member
ArmyVette's Avatar
Not sure I agree with the above posts. The tires are marked on uni-directional. Installing them incorrectly may also impact braking performance in addition to the degraded wet performance mentioned above.
That's also why your owner's manaul says not to rotate your tires.
Just my $.02 worth!
ArmyVette is offline   Reply With Quote
Old 05-27-2004, 08:07 PM   #7
rocco16
CF Senior Member
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Default Re: Can you switch tires left to right? (ArmyVette)
Other than compromised wet performance, I did not notice any difference in running directional tires "backward". (AVS ES100's on my VW)
Larry
code5coupe
rocco16 is offline   Reply With Quote
Old 06-03-2004, 06:08 PM   #8
MrBill
CF Member
I rotate mine left to right, but I dismount/remount to keep them directional. Not because I turn to the right harder, but because the camber makes the insides wear faster. I keep them directional 'just because.'
MrBill is offline   Reply With Quote
Old 06-05-2004, 10:04 AM   #9
rocco16
CF Senior Member
rocco16's Avatar
Default Re: Can you switch tires left to right? (MrBill)
Doing it Mr. Bill's way is the 'correct' way.
But I would not be leery of running my MX's backward.
Larry
code5coupe
[Modified by rocco16, 8:06 AM 6/5/2004]
Old 06-08-2004, 02:28 AM   #10
Too Tall Z06
CF Member
Yes, you can run them backwards, dry without issue. The tread is only for moving water away.
However, if you just go left to right, then you will still be wearing on the outside of the tire. The $80 might save you a couple of hundred in premature tire replacement.
Too Tall Z06 is offline   Reply With Quote
Old 06-08-2004, 06:16 PM   #11
mountainbiker2
CF Senior Member
Looks like my next set I will try to determine which is better. To dismount or just switch left to right. Thanks again for the reply's.
Steve
Reload this Page Can you switch tires left to right?
Tags
corvette, left, tire
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
96 c4 pulling to left groran C4 General Discussion 12 02-14-2005 11:04 PM
Picked Up My Car At MMS, & I Went To The Track Today... & Here Are The Results! alfromsd C5 Tech 18 09-16-2002 05:19 PM
Best place to buy 700R4 chrisgable C3 Tech/Performance 37 06-04-2002 01:23 PM
Advice needed on costs to get an 82 up and running jwatty C3 Tech/Performance 12 05-10-2002 12:46 AM
Anyone pay $130 for Alignment after they Lower Z06 THIS C5 Z06 Discussion 24 03-09-2002 01:14 PM
Proper proceedure to heat cycle new track tires Mike Schriber Autocrossing & Roadracing 17 01-19-2002 09:01 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
