Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-17-2004, 02:41 PM   #1
lager99
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
lager99's Avatar
Default Speed Ratings?
How do speed ratings work on drag radials? If they are a traction A temp A, are they safe for high speeds? Looking at the Nitto's right now.
lager99 is offline   Reply With Quote
Old 05-18-2004, 10:32 AM   #2
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
Default Re: Speed Ratings? (lager99)
I have taken the BFG drag radials up to 147+ many times with no ill effects
Luke@tirerack is online now   Reply With Quote
Old 05-18-2004, 10:59 AM   #3
lager99
CF Senior Member
St. Jude Donor '06
lager99's Avatar
Default Re: Speed Ratings? (Luke@tirerack)
Do you mean on a test machine?
Old 05-18-2004, 11:50 AM   #4
Luke@tirerack
St. Jude Donor '11
if you call my '56 Belair drag car a test machine
Old 05-18-2004, 11:53 AM   #5
lager99
CF Senior Member
St. Jude Donor '06
lager99's Avatar
Ya, but that doesn't mean it was safe...they might be though. I just want to know if it's safe to do 150mph down a desert highway with DR's...don't need a blowout. :shocked:
Old 05-18-2004, 04:17 PM   #6
Luke@tirerack
St. Jude Donor '11
in those conditions I would so "NO" that's not what they are designed for ..... the sidewall construction is designed to offer great launch traction but little cornering traction and sidewall/steering response ..... they are perfectly capable of high speeds but, high speeds and turns not too mention less than perfect road conditions I wouldn't risk it myself
[Modified by Luke@tirerack, 2:18 PM 5/18/2004]
Old 05-18-2004, 05:07 PM   #7
lager99
CF Senior Member
St. Jude Donor '06
lager99's Avatar
Damn!!! I'm going thru Montana next weekend!
Old 05-26-2004, 05:59 PM   #8
ArmyVette
CF Senior Member
ArmyVette's Avatar
Here's come good general information on speed ratings, etc., from Tire Rack.com.
http://www.tirerack.com/tires/tirete...eral/speed.jsp
ArmyVette is offline   Reply With Quote
Reload this Page Speed Ratings?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
speed rated tires tigers123 C3 Tech/Performance 23 09-10-2005 07:57 AM
Firestone Firehawk Wide Ovals Groovilator C5 Z06 Discussion 19 02-25-2005 10:12 PM
Just order my NITTO R2s today for my Zo6..... Mopar Jimmy C5 Z06 Discussion 27 01-29-2005 11:41 PM
The LS2 Z51 at the new top speed champ? Terry Humiston C6 Tech/Performance 62 04-29-2004 10:40 PM
tire speed ratings??? scorciae C3 Tech/Performance 9 01-30-2003 04:46 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
