01-22-2004, 12:58 PM
CF Senior Member
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Will a 295/35/18 tire fit 18x10.5 wheel?
:confused:
01-22-2004, 10:19 PM
CF Senior Member
Re: Will a 295/35/18 tire fit 18x10.5 wheel? (Buckmaster)
Absolutely. That's what I'm getting for my 18x10.5 rear wheel. I believe that is the OEM size for a Z06 Vette.
01-24-2004, 11:04 PM
CF Senior Member
CI 3-4-5-6-7-8-9-10 Veteran
Re: Will a 295/35/18 tire fit 18x10.5 wheel? (SJTrance)
That's what came on my car. :iagree:
01-25-2004, 04:52 AM
CF Senior Member
Re: Will a 295/35/18 tire fit 18x10.5 wheel? (Fast Lane)
A 315/30 will fit too. :)
01-26-2004, 12:00 AM
CF Senior Member
yes . just put a set of michelin pilot sports on 18x10.5 and 17x9.5 wheels
295x35x18 and 265x40x17. work great. really like them. :auto: :seeya
01-31-2004, 03:29 PM
CF Member
Re: Will a 295/35/18 tire fit 18x10.5 wheel? (BAM92)
How wide can you go on a 10.5" rim? Is 315 the max? or can you pack on another 20 mm?
[Modified by JLMonaco, 7:29 PM 1/31/2004]
02-06-2004, 11:42 PM
CF Senior Member
Re: Will a 295/35/18 tire fit 18x10.5 wheel? (2REDS)
Im looking for the same info, but dont want something thats going to hang out of the wheel well, so if i use the 295/35/18 will it still be inside of the well?
02-07-2004, 04:24 AM
CF Senior Member
Re: Will a 295/35/18 tire fit 18x10.5 wheel? (bowtiebubba)
Narrowest recommended wheel for a 335 is 11". Tire still rolls over edge a bit. I have 285/30 on a 18x11" wheel which is actually too narrow for the wheel. 285 to 315 works with a 10.5" wheel.
02-26-2004, 12:48 AM
CF Senior Member
yep that is STOCK Z06 Sizes and I have 18 X 10.5 Z06 Rear Wheels with BFG Drag radials which are also 295/35/18.
Long time no talk Buckmaster, Hope all is well.
The Bandit....................... :cheers:
02-26-2004, 03:33 AM
CF Senior Member
Works for me... :cheers:
[Modified by 4DCYKEY, 1:35 AM 2/26/2004]
02-27-2004, 08:17 PM
CF Senior Member
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Location: Making my carbon footprint as BIG as possible
02-28-2004, 08:01 AM
CF Senior Member
Re: Will a 295/35/18 tire fit 18x10.5 wheel? (Maineiac)
Just some basic info please. My 2000 has 17 X 8.5s and 18X 9.5s I think????? Is that the standard width? What do the numbers represent 245/45, I know one is height and one width? So 255 is wider then 245 and 45 is higher then 40?
So if I go to from 17s up front to 18s and have 245x17 x 8.5 and am going to 18x9.5 how do I know how wide I can go and how much I need to reduce the height of the tire to still fit? Btw going from 18 x9.5 on the rear to 18 x 10.5s.
thanks (does all this make sence?)
03-03-2004, 05:38 PM
CF Senior Member
Re: Will a 295/35/18 tire fit 18x10.5 wheel? (Greg00Coupe)
03-17-2004, 04:46 PM
CF Senior Member
So who has the 315 set up on a 10.5 rim ? Any pics I would like to go to this set up with Z06 wheels. Thanks :seeya
Tags
18 , 18x10 , 18x105 , 295 , 2953518 , 35 , 35r18 , corvette , fir , fit , rims , tire , tires , wheel , wide
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
