Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-04-2004, 02:24 AM   #1
MyFirstCorvette
CF Senior Member
MyFirstCorvette's Avatar
Default What size 16" rims and ET Streets for a C5?
I'm looking for inexpensice 16" rims to mount some ET Streets that I'm going to buy to match the rims for my C5
For the rims what bolt pattern, offset and width do I need? Any recommendations on a cheap, light rim?
What size ET Streets should I use?
Traction is very important, this is a Procharged car with an ATI-D1SC that makes the "normal" amount of HP for this setup. I'd like to put the widest tire possible. (without looking ridiculous)
Thanks in advance for any suggestions! :cheers:
MyFirstCorvette is offline   Reply With Quote
Old 01-10-2004, 12:39 PM   #2
dmarks1961
CF Member
dmarks1961's Avatar
Default Re: What size 16" rims and ET Streets for a C5? (MyFirstCorvette)
I bought a set of 99 Camaro 16" rims for $100 (4). They work perfectly with 10.50 x 26.0 ET Streets. You willhave to grind just slightly on the tops of rear spindles. Good luck. :seeya
dmarks1961 is offline   Reply With Quote
Old 01-11-2004, 01:24 PM   #3
Bill C
CF Senior Member
Default Re: What size 16" rims and ET Streets for a C5? (dmarks1961)
:iagree: This will work. I spray painted the area and used a metal file. When you put the wheel back on it will remove the paint when it hits it. Respray and grind.
Bill
Bill C is offline   Reply With Quote
Reload this Page What size 16" rims and ET Streets for a C5?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ET Streets on a C5 HawkIVette Drag Racing 15 05-07-2004 10:20 PM
anybody have 1/4 times with a magnuson KABAL182 C5 Forced Induction/Nitrous 34 09-29-2002 04:02 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
