Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-26-2003, 07:47 PM   #1
Ricestalker
CF Member
Default C5 Autocross/track day tire& wheel question
I'd like to be able to rotate my expensive race rubber so I was thinking of getting four 18s or four 17s instead of two 18s and two 17s like my stock C5 wheels. Is this a mistake? Should I stay with my stock wheel sizes, if not which way should I go? Four 17s or four 18s?
Thanks,
Chet
Ricestalker is offline   Reply With Quote
Old 12-29-2003, 07:20 AM   #2
urtoslo
CF Senior Member
urtoslo's Avatar
Default Re: C5 Autocross/track day tire& wheel question (Ricestalker)
Rotating your tires around is a good way to maximize your investment. The only thing stopping you is will they fit (do they rub, will they clear all the chassis components) and what class will you end up in for autoxing.
urtoslo is offline   Reply With Quote
Old 12-29-2003, 10:29 AM   #3
ZR1 MK
CF Senior Member
ZR1 MK's Avatar
It depends on your tire choice. What race rubber do you plan to use? Track or autocross? Some tires are only manufactured in 17" size, some only in 18" size. 18s will allow for larger brake upgrades, but are heavier.
Mike
ZR1 MK is offline   Reply With Quote
Old 12-29-2003, 10:57 AM   #4
TedDBere
CF Senior Member
TedDBere's Avatar
Send a message via AIM to TedDBere
I've stayed with the 17's and 18's, but I'm in SS class and have to. If you're using Hoosiers you can have them flipped on the rims about halfway through the treads since they are not uni-directional.
Many of the non-SS classes run with 17's all the way around, but your speedometer will need to be reprogrammed, if you care! I've even seen 18's on the front with 17's in the rear, to get bigger front brakes on the car.
Good Luck.
:steering:
TedDBere is offline   Reply With Quote
Old 12-29-2003, 03:52 PM   #5
DKTZ06
CF Senior Member
DKTZ06's Avatar
Default Re: C5 Autocross/track day tire& wheel question (TedDBere)
Kumhos can also be flipped. The directional stamp on the blackwall is residual from old tire molds .... and by the time you need to flip 'em, there isn't much wet traction tread left anyhow.
Running 315/35 17's all around puts you at less than a 0.5" taller than normal tires. That shouldn't be a big change in the speedo calibration .... at the most, you'd be off by 1-2 mph. However, with this setup, the car will be more inclined to oversteer (not necessarily a bad thing) and the wheel change bumps you to ASP. You'll need a lot more than just wider wheels and rubber to be competitive in ASP! ;)
WRT wheel size, I'd recommend staying with 17's ... better tire size options and a fair bit cheaper than 18's.
[Modified by DKTZ06, 7:57 PM 12/29/2003]
DKTZ06 is offline   Reply With Quote
Reload this Page C5 Autocross/track day tire& wheel question
Tags
17, 18, autocross, c5
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Any way to improve UNDERSTEER? 1998 GTR C5 Tech 20 05-02-2005 11:04 AM
Suspension/AutoX Questions 1999 C5 Coupe Autocrossing & Roadracing 17 05-24-2004 03:11 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
