Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-20-2003, 03:51 PM   #1
neile
CF Senior Member
CI 3-5-8 Veteran
neile's Avatar
Default Driver Side Wear vs Pass. Side Wear
Okay was under the '03 Z06 checking last weekends work when I noticed my stock Super Car Tires are wearing at differerent rates (inflation is the same on both). Driver side is down to 0.0705 inches above the wear indicator bars, while the passenger side is 0.1471 inches..! This is at 11K miles.
What gives? Is this normal? Or do I have a rear end problem?
Neil
neile is offline   Reply With Quote
Old 09-22-2003, 11:43 AM   #2
leadfoot4
CF Senior Member
leadfoot4's Avatar
Default Re: Driver Side Wear vs Pass. Side Wear (neile)
I would think that a 4 wheel alignment is in order. I can see different rates of wear between front and rear, but side to side should be pretty much the same.
leadfoot4 is offline   Reply With Quote
Old 09-22-2003, 05:37 PM   #3
MIke350
CF Senior Member
MIke350's Avatar
Send a message via AIM to MIke350
Default Re: Driver Side Wear vs Pass. Side Wear (leadfoot4)
i find that i wear the pass. side (both front and rear although more in the rear) kind of like your saying. after noticing this i paid more attention to how i drove and pretty much found out that even when im not thinking about it or paying attention i corner a lot harder on left turns and im a lot more comfortable going into a left harder when driving faster. im not sure if that is the reason i wear the pass. side faster or not because the last time i put new tires on and got a new alignment it was not that far off. maybe you go into right turns harder?:confused:
MIke350 is offline   Reply With Quote
Reload this Page Driver Side Wear vs Pass. Side Wear
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette Parts News! New C6 Section! 8/28/04 CorvettePartsBob Ken's Newsletters 9 10-05-2004 12:23 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
