Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-30-2003, 03:49 AM   #1
camarodoctor
I ♥ My Corvette
Support Corvetteforum!
camarodoctor's Avatar
Default Can I put 17" C5 fronts on the rear of my '01 Z06?
I am interested in running at Bonneville Salt Flats and need a narrower rim/tire combo than the 9.5" fronts / 10.5" rears (for safety as well as smaller frontal area ). Will the regular C5 17" rims fit on the rear of my car without modification/grinding? Thanks.
gregg
'01 Z06
camarodoctor is offline   Reply With Quote
Old 09-05-2003, 03:44 AM   #2
VETTENV
CF Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
VETTENV's Avatar
Send a message via Yahoo to VETTENV
Default Re: Can I put 17" C5 fronts on the rear of my '01 Z06? (camarodoctor)
I asked this question a few weeks ago and everyone said YES! :yesnod: I'm wanting to mount a set of drag radials on mine.
VETTENV is offline   Reply With Quote
Old 09-05-2003, 07:27 AM   #3
Allthrottleandsomebottle
Race Moderator Moderator
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
NCM Ambassador
Allthrottleandsomebottle's Avatar
That would be a big YES
Ran at set of 17" Mag rims with Nitto 555 275/40/17s at Cruise-In IV on tha back for autoxing, 1/4 mile and around town. With the smaller tire dia. it gave me about a 3.30 rear vs. 3.15 stock.......every bit helps!
You can just see them in my signature :lol:
You may get service abs, reduced power, etc. because of having 17" tires/rims at all 4 corners. The computer likes to see the 1" difference front to rear. It drove fine, but if you get the message, just tap the brakes and/or hit the TC button.......have a nice day.
:cheers:
Allthrottleandsomebottle is offline   Reply With Quote
Old 09-11-2003, 09:33 PM   #4
out2run
CF Senior Member
out2run's Avatar
Default Re: Can I put 17" C5 fronts on the rear of my '01 Z06? (ALLTHROTTLE&NOBOTTLE)
Hello
Would the 17x8.5" wide sawbladesfrom a '93 be good for mounting some slicks on a "03?
out2run is offline   Reply With Quote
Old 09-12-2003, 07:26 AM   #5
Cruise-In V Veteran
NCM Ambassador
Default Re: Can I put 17" C5 fronts on the rear of my '01 Z06? (out2run)
Not a C4 guy, But I would think you should at least check the back spacing. Post over in the C4 area, I am sure youll get a quick answer. :yesnod:
Reload this Page Can I put 17" C5 fronts on the rear of my '01 Z06?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C5 and general audio FAQ scott_fx Audio/Electronics 172 11-06-2011 10:25 AM
C5 Bose upgrade wiring notes 99HT Audio/Electronics 11 10-08-2011 05:45 PM
C5 Bose Upgrade Info 99HT Audio/Electronics 18 08-16-2004 04:02 AM
C5 Stereo Install Lessons Learned (long) (all text) MSIP Audio/Electronics 10 06-10-2004 07:29 PM
I just put wheels-tires and lowered my aqua roadster ... Opinions ?? madquake C4 General Discussion 35 03-29-2004 09:53 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
