Kuhmo Ecsta MX
Kuhmo Ecsta MX
I had some Kunho Ecsta MX's installed last week. Drove home from the installer and the car sat for 5 days (rain). Drove the car Sat and the steering wheel shook so bad I thought a wheel was loose. Drove another 5 miles and everything smoothed out. Do these tires develope flat spots that fast, or did it do this just because they were new?
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Re: Kuhmo Ecsta MX (STL94LT1)
Yikes. I've had mine for 4 weeks and no problems at all. I did a lot of research and never read anything like that.
I had mine sat for more than a week, no problems like what you described. :nonod:
[Modified by vette_dreamer, 8:28 PM 6/19/2003]
Isolate the problem and get the tire replaced, the symptoms won't get any better. These are really good tires on the raod and on the track, but seem to tend to exhibit these symptoms. I had a problem with this on my C4 and I know of it on an Audi A8 running MXes as replacements. Be sure to take care of this soon, so that there may be a warranty to help you (Tire Rack will replace, no questions asked, for 90 days from the order date). A good tire shop can do a road-force variance test to help find the offending tire, but that alone may not be enough. If the tires are the same sizes F/R, try rotating them; if the shake moves from your hands to your butt, you'll have at least eliminated 2 tires as suspects.
I have read several stories on different boards about the MX's "flat-spotting" after sitting for a couple of days.
Seems to be common, but goes away after a few miles of driving.
I just had a set installed on my 93'.
It sat for about a week. Noticed a little bit when cold and went away in less than a mile of driving.
Sure hope this is not a problem for the winter. Sounds like I may have to jack the car up and put on stands.
JB
JB
