06-11-2003, 09:44 PM
CF Senior Member
Cruise-In II Veteran
Re: Tire pressure in Kumho MXs (SDVette)
Keeping the same sized tire you'd want to run the same pressure as stock. The same sized tire will give the same contact footprint at the same pressure, and that is what you want.
If you're carrying heavy loads (not applicable to corvettes) you need more pressure in the tire. Just think the tire psi is carrying the vehicle weight via the area of the contact patch.
Increase the tire contact patch with larger tires and the required pressure will go down.
Without air, the runflats only support the car on the sidewalls. You still need the air to force the tire off the sidewall and onto the tread.
Look on the door of the car, it gives you the pressure for the stock tire size, 30 psi.
