Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-07-2003, 08:26 AM   #1
Micky6
Junior Member
Micky6's Avatar
Default Who does wheel widening ( weld in section ) in Toronto, Canada ?
Want to widen 93 wheels ! ( 9.5 to 11" ) ZR-1's stick out
Micky6 is offline   Reply With Quote
Old 06-10-2003, 05:31 AM   #2
71coupe
CF Senior Member
71coupe's Avatar
Default Re: Who does wheel widening ( weld in section ) in Toronto, Canada ? (Micky6)
You might want to call Stockton Wheel:
http://www.stocktonwheel.com/wheel_widening.htm
It looks like they only do steel wheels, but they may be able to steer you in the right direction. P.S. - I have delt with them before and they are good guys to work with.
[Modified by 71coupe, 1:32 AM 6/10/2003]
71coupe is offline   Reply With Quote
Old 06-10-2003, 08:26 AM   #3
leadfoot4
CF Senior Member
leadfoot4's Avatar
If you don't mind travelling 3 hours or so, to Rochester, NY, try this person. His name is Phil Ackerson, he and his son make, widen, and repair race car wheels. I understand that he was also widening aluminum wheels. Try either 585-334-5658 or 585-359-8722.
leadfoot4 is offline   Reply With Quote
Old 06-18-2003, 02:42 PM   #4
ZR1 MK
CF Senior Member
ZR1 MK's Avatar
I have a source in New Jersey and Michigan. I shipped mine without problems. If you choose shipping I can give info.
Mike
ZR1 MK is offline   Reply With Quote
Old 06-28-2003, 02:46 PM   #5
tobijohn
CF Senior Member
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
Support Corvetteforum!
tobijohn's Avatar
Default Re: Who does wheel widening (ZR1 MK)
To ZR1 MK:
I've got an interest and I don't mind shipping so if you could post the contact info, it would be much appreciated. I happen to like sawblades but I would also like to run 315s on the back of my 96 LT-1 so I unless the price is unreasonable, I thought I'd pick up a couple used sawblades and just have them widened, throw them on the back and use the current 9 1/2" rear rims on the front.
Thanks...
tobijohn is offline   Reply With Quote
Old 06-30-2003, 09:57 AM   #6
ZR1 MK
CF Senior Member
ZR1 MK's Avatar
Default Re: Who does wheel widening (tobijohn)
I had mine done by Weldcraft for $175 per wheel plus shipping. I had fronts 9.5" to 11" and rears 11" to 12". Wheels can only be increased in width on the backside. My fronts have extra thick rotor hats and rears needed a 1/4" spacer at minimum. Do measurements and plan ahead to avoid problems/mistakes. Make sure you stress that the wheel measures exactly what you specify.
Weldcraft
15091 Northville Rd
Plymouth MI
734 420-2211
Wheel Works
1703 RT 130
Burlington NJ
609 387-4488
Mike
Old 06-30-2003, 11:55 AM   #7
tobijohn
CF Senior Member
tobijohn's Avatar
To ZR1 MK:
Thanks for the info!
Old 07-03-2003, 05:50 PM   #8
cdsmith
CF Senior Member
What series tire do you run on the rear? 335?
cdsmith is offline   Reply With Quote
Old 07-04-2003, 10:45 PM   #9
Micky6
Junior Member
Micky6's Avatar
To any LT-1 er's
Thanks for the info, I'm widening the wheels on a 93 LT-1 40th
I want to widen, my existing rear 9.5" sawblades, to at least 11" to take a 315.
I know the wheel has to be widened on the backside, but
how wide can I go, + 1.5"( 11"), + 2" (11.5") , or + 2.5" ( 12") ?, and can / should I use a spacer to bring them out more, towards the fender to increase inside clearance?
I've seen the five spoke Grand Sport 11" wheel on some LT-1's, and it seems to fit fine
By the way, my car has been lowered, a little over an inch, (inch and a half w/ a full tank )!
Thanks, Mike
[Modified by Micky6, 8:49 PM 7/4/2003]
Old 07-05-2003, 12:35 PM   #10
tobijohn
CF Senior Member
tobijohn's Avatar
Default Re: Who does wheel widening (Micky6)
Micky6 wrote:
"I want to widen, my existing rear 9.5" sawblades, to at least 11" to take a 315"
I want to do the same but have some concerns (see my Maximum Offset and Backspace for LT1 coupe rear wheels? post earlier in this same section: http://forums.corvetteforum.com/zerothread?id=594521). It seems to me that any aftermarket 11" rims while maintaining the proper offset, must have a larger frontspacing because it sure looks like any increase greater than 1" over stock backspacing will cause rubbing with the the stock muffler system at the very least and perhaps even suspension components. Maybe my math is off but if this is truly the case, it seems to me that unless wheel spacers are used, a stock 9.5" sawblade that has been widened to 11" just won't fit without inside rubbing problems. I'm going to look to see if I can find the dimensions for the stock backspace and front spacing (as well as aftermarket 11"rims) to see if this might shed some light on the subject but in the meantime if anyone already knows or has actually widened a stock 9.5" rim to 11", please post your experience, thanks...
P.S.: Here's a link that might prove helpfull with visualization and terminology: http://www.fikse.com/fitment.html
[Modified by tobijohn, 11:38 AM 7/5/2003]
Never mind, I found the info I was looking for and widening 9.5" stock sawblades to 11" ain't gonna work, at least not without spacers and/or fender flares....
[Modified by tobijohn, 2:44 AM 7/6/2003]
Old 07-07-2003, 09:43 AM   #11
ZR1 MK
CF Senior Member
ZR1 MK's Avatar
Default Re: Who does wheel widening (cdsmith)
I run 315.35.17 front, 335.35.17 rear.
Mike
Old 07-07-2003, 09:50 AM   #12
ZR1 MK
CF Senior Member
ZR1 MK's Avatar
I don't think this will work for you. I will be changing from race tires to street tires this week. When I do, I can take my front widened wheel (11" from 9.5") and mount it to the rear. I am assuming all front and rear 9.5" wheeels have the same offset.
Mike
Reload this Page Who does wheel widening ( weld in section ) in Toronto, Canada ?
Tags
c3, canada, corvette, rims, service, welding, wheel, widening
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
