Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-03-2003, 01:35 PM   #1
cOvette
CF Senior Member
cOvette's Avatar
Default Largest Diameter tire that will fit 1995?
Without hitiing anything.
cOvette is offline   Reply With Quote
Old 06-03-2003, 08:08 PM   #2
RM 4 TWO
CF Senior Member
RM 4 TWO's Avatar
Send a message via AIM to RM 4 TWO
Default Re: Largest Diameter tire that will fit 1995? (cOvette)
Depends on wheel offset. There's a guy in my region that stuffs 335's under the rear of his LT4. He says he hasn't modified anything and only has minor rubbing under hard cornering. :confused:
RM 4 TWO is offline   Reply With Quote
Old 06-04-2003, 12:05 AM   #3
cOvette
CF Senior Member
cOvette's Avatar
Default Re: Largest Diameter tire that will fit 1995? (RM 4 TWO)
Thanks, but notice I asked for diameter, not width.
I autocross 315's all around with no problems, but for off road RallyCross i need an off road tire.
Old 06-04-2003, 12:52 PM   #4
RM 4 TWO
CF Senior Member
RM 4 TWO's Avatar
Sorry:withstupid: I believe max is 19". Check TireRack.com or with "Todd@Tires.com". He's a forum member that works for Discount Tire. He can generally be found in the Wheels & Tires section .
[Modified by RM 4 TWO, 9:53 AM 6/4/2003]
Old 06-08-2003, 04:35 AM   #5
BAM92
CF Senior Member
BAM92's Avatar
I have seen 20" wheels on a vette. Looked funny. 19" would probably be better and if you can afford don't go less than 18". Just my opinion.
BAM92 is offline   Reply With Quote
Old 06-08-2003, 10:22 AM   #6
cOvette
CF Senior Member
cOvette's Avatar
Default Re: Largest Diameter tire that will fit 1995? (BAM92)
Thanks for the replies, but again, I am asking what is the largest TIRE (not wheel) diameter.
Old 06-09-2003, 11:08 PM   #7
USAZR1
CF Senior Member
USAZR1's Avatar
My ZR-1 has 345/35/18 Michelins. Is that tall enough for you?
USAZR1 is offline   Reply With Quote
Old 06-10-2003, 11:58 AM   #8
RM 4 TWO
CF Senior Member
RM 4 TWO's Avatar
Default Re: Largest Diameter tire that will fit 1995? (USAZR1)
USAZR1, What did you have to do to stuff 345 under there and what offset are you using? :eek:
Old 06-17-2003, 12:36 PM   #9
USAZR1
CF Senior Member
USAZR1's Avatar
The car has 18x12.5 OZ Mitos with approximately 34mm offset. The 345's fit fine on a ZR-1.
Reload this Page Largest Diameter tire that will fit 1995?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
