Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-01-2003, 05:24 PM   #1
ridged84
CF Senior Member
ridged84's Avatar
Default So Confused
Can someone please tell me what does offset mean. I know what the back spacing is but this offset thing is driving me nuts.Some times i see a -8 then i see just 8 :crazy: . Im looking to put on some AR torq thrust II's on my 72 coupe and i want to make sure i order the right ones
ridged84 is offline   Reply With Quote
Old 06-02-2003, 07:54 AM   #2
leadfoot4
CF Senior Member
leadfoot4's Avatar
Default Re: So Confused (ridged84)
Offset is the amount that the mounting pad is located from the centerline of the wheel. Positive offset moves the center toward the outside of the car, similar to a FWD wheel. Negative offset moves the center toward the inside of the car, like the "deep dish" wheels of the '60s and 70's.
The Torque Thrusts are my all-time favorite wheels, and will look great on your '72. Just make sure that you get wheels that are designed to fit a C-3, as the back side of the spokes are made with extra clearance for the large Corvette brake calipers.
leadfoot4 is offline   Reply With Quote
Old 06-02-2003, 03:58 PM   #3
Todd@Tires.com
CF Senior Member
Todd@Tires.com's Avatar
Send a message via AIM to Todd@Tires.com
Default Re: So Confused (leadfoot4)
INFO CENTER
Wheel Offsets
The offset of a wheel is what locates the tire and wheel assembly in relation to the suspension. More specifically, it is the measured distance between the hub mounting surface and the center line of the rim. Below is an explanation of the various types of offsets which are pictured in the above graphic.
Positive Offset
A positive offset occurs when the hub mounting surface is on the street side (the side you see) of the center line of the rim. Most factory rims will have this type of offset.
Zero Offset
When the hub mounting surface is centered within the rim, it is known as a zero offset.
Negative Offset
If the hub mounting surface is on the brake side of the center line of the rim, it is considered a negative offset or “deep dish”.
Note that extensive negative offset can potentially cause increased steering wheel kick-back and place additional stresses on the vehicle's entire suspension.
Todd@Tires.com is offline   Reply With Quote
Old 06-05-2003, 08:53 PM   #4
ridged84
CF Senior Member
ridged84's Avatar
Default Re: So Confused (Todd@Tires.com)
Thanks Todd ,Great info it got me on track.
Reload this Page So Confused
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
OMG...I'm so confused CCA Corvette Parts C5 General 16 11-17-2004 02:22 PM
brake and fuel lines...im so confused 71vetteLT-1 C3 Tech/Performance 13 09-15-2004 02:20 AM
So confused, sell it or not? ZF Six C4 General Discussion 21 03-30-2004 09:50 AM
I am so confused - do we know the hp or not for the 2005 C6? KGjevre C6 Corvette General Discussion 36 12-16-2003 09:36 PM
I'm so confused! help me suspension Gurus! '79ProwlerOrange C3 Tech/Performance 13 12-06-2002 04:30 AM
Bogus HP mods for the L98. I am so confused... chuckster C4 Tech/Performance 12 07-23-2002 09:41 PM
L-82? 4 spd? L-what? I'm so confused! Can anyone help me out please? VetteGoVroom82 C3 Tech/Performance 17 01-28-2002 11:22 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
