Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-15-2003, 01:13 AM   #1
rweissen
Junior Member
rweissen's Avatar
Default Tire dressing: what do you use?
I would like to put some tire dressing on my 2003 Z06 to keep the new tire look and to basically maintain the tires, avoid dry rubber white look. I don't like armoral since it looks like oil, and I don't like that wet tire look. What else is there?
Rob
rweissen is offline   Reply With Quote
Old 03-15-2003, 07:59 PM   #2
LB66383
CF Senior Member
Default Re: Tire dressing: what do you use? (rweissen)
The best I've found is Mequiar's. It looks good and it lasts.
LB66383 is offline   Reply With Quote
Old 03-15-2003, 08:06 PM   #3
rocco16
CF Senior Member
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Here's how I avoid the oily look with Armour-All. Put it on, let it soak about 3-5 minutes (depending on temperature) then buff it off with a dry rag. It will have the soft, dry look of fresh rubber and the protection will last for several weeks.
Larry
code5coupe
:seeya
rocco16 is offline   Reply With Quote
Old 03-16-2003, 05:06 PM   #4
rweissen
Junior Member
rweissen's Avatar
Default Re: Tire dressing: what do you use? (rocco16)
Thanks guys, I'll give both a try on my other cars and see what they look like.
Rob
Old 03-18-2003, 08:26 AM   #5
BostonJoel
CF Senior Member
BostonJoel's Avatar
I've tried them all...and I like Stoner MSLT (More Shine Less Time). Go once around for matte finish, twice around for shiny finish. You can buy in auto stores or direct from Stoner by the case..around $30-$35 delivered.
BostonJoel is offline   Reply With Quote
Old 03-18-2003, 09:29 AM   #6
Luke@tirerack
Platinum Supporting Vendor
St. Jude Donor '11
currently the only tire dressing that does not have a detrimental effect on the tire itself is Meguiers Endurance and they have 2 different types 1 shiny and 1 matte
Luke@tirerack is offline   Reply With Quote
Old 03-19-2003, 09:33 AM   #7
GaryZ06
CF Senior Member
Default Re: Tire dressing: what do you use? (Luke@tirerack)
Zaino Z-16 :D
[Modified by GaryZ06, 8:34 AM 3/19/2003]
GaryZ06 is offline   Reply With Quote
Old 03-27-2003, 01:36 AM   #8
84FromHell
CF Senior Member
84FromHell's Avatar
303 Aerospace Protectant if you want the natural, new rubber look .. no silicones or oils
84FromHell is offline   Reply With Quote
Old 03-27-2003, 04:24 AM   #9
Reid @ Iforged
Junior Member
Send a message via AIM to Reid @ Iforged
Default Re: Tire dressing: what do you use? (LB66383)
:iagree: :iagree: and it's smells good also :)
Reid @ Iforged is offline   Reply With Quote
Old 03-27-2003, 04:34 PM   #10
Jammer
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
Jammer's Avatar
I've always liked the Meguiers
Jammer is offline   Reply With Quote
Old 03-27-2003, 10:52 PM   #11
joalyons
CF Senior Member
Send a message via AIM to joalyons
Meguiers, its the best
joalyons is offline   Reply With Quote
Old 03-27-2003, 11:05 PM   #12
rweissen
Junior Member
rweissen's Avatar
Default Re: Tire dressing: what do you use? (joalyons)
Just ordered some endurance from
http://www.meguiars.com/product_show...cfm?SrcLine=CW
[Modified by rweissen, 10:07 PM 3/27/2003]
Old 03-28-2003, 01:50 AM   #13
MIke350
CF Senior Member
MIke350's Avatar
Send a message via AIM to MIke350
Meguiers gel most of the time, takes a bit longer but last longer too
MIke350 is offline   Reply With Quote
Old 04-21-2003, 01:14 PM   #14
corvette2day
CF Member
corvette2day's Avatar
I use Son-Of-A-Gun (no kidding). Spray on wipe off. Takes 10 seconds a tire. Leaves a flat black appearance that lasts.
corvette2day is offline   Reply With Quote
Old 04-21-2003, 02:21 PM   #15
SWCDuke
CF Senior Member
Default Re: Tire dressing: what do you use? (corvette2day)
I use a 50/50 mix of Armor All and distilled water - spray some on the tire and then work it in with an old natural bristle paint brush, which gives the tire a nice consistent satin finish - not shiny at all.
New tires have a lot of mold release on them and you often can't see it on a new tire, but this is what eventually causes the tire to turn brown. The only way I have found to remove the mold release is to scrub the tire with various brushes using paint thinnner and wipe off the residue. The rags you use must be throughaway because the mold release will never wash out.
Since I typically buy tires by mail order and have them delivered to the house I now scrub down the sidewalls with paint thinner before I take the tire down to my tire shop to be mounted and balanced.
Duke
SWCDuke is offline   Reply With Quote
Old 04-21-2003, 06:04 PM   #16
joevette57
CF Senior Member
joevette57's Avatar
Send a message via AIM to joevette57
Default Re: Tire dressing: what do you use? (Joel Forman)
:iagree:
A guy gave me a can several years ago at Corvettes@Carlisle. He said if I give you a can now, you WILL buy more later..... He was right. This stuff is the best!!!!
:cheers:
[Modified by joevette57, 5:05 PM 4/21/2003]
joevette57 is offline   Reply With Quote
Old 04-22-2003, 08:44 AM   #17
BostonJoel
CF Senior Member
BostonJoel's Avatar
Default Re: Tire dressing: what do you use? (joevette57)
:iagree: :iagree:
Same thing happened to me. You can buy it by the 12 can case direct from Stoner...about $30 to $35 a case delivered UPS. I use it on the Corvette and two daily drivers. A case lasts me two years.
[Modified by Joel Forman, 7:45 AM 4/22/2003]
Old 04-22-2003, 05:49 PM   #18
Bodhi
CF Senior Member
Bodhi's Avatar
Do NOT use the High Gloss....I bought some of this 2 weeks ago....BIG MISTAKE....I put it on after I washed the Vette on Saturday...the car sat in my garage for a week before I even drove it......you would think the tire dressing had time to dry :smash:
Well when I got home I had HUNDREDS of tiny black dots all over the side of my car...the tires had flung that crap all down the side! It was not a major problem....only took me about 15 minutes with the detailer spray to clean it up but I was still :mad
I have since read other people's accounts of the same thing happening...so I bought some of the high endurance to try....I hope it doesn't have the same problem.
I will say since my car is white it was very easy to see the little dots....on a darker car you might not have even noticed them.
Bodhi is offline   Reply With Quote
Old 04-23-2003, 02:51 PM   #19
SNISTER
CF Senior Member
Default Re: Tire dressing: what do you use? (Bodhi)
This has happened to me with several different kinds of tire dressing and usually has to do with putting too much of it on the tire in the first place. The tendency to want to saturate the thing which you use to apply the dressing is subconcious, but usually results in over-application of the stuff. It gets caught in all the little nooks and crannies on the tire sidewall (some worse than others) and doesn't dry (it's not water based, so why would it?), but instead gets flung around when you first drive the car.
I use some stuff called Black Magic from my local Autozone, Kragen, etc. and apply it with a Meguires contoured foam applicator. The foam applicator works MUCH better than any rag and reduces the tendency to over-apply the tire dressing.
SNISTER is offline   Reply With Quote
Reload this Page Tire dressing: what do you use?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Best Tire Dressing Product Z Factor Car Care Discussion 55 12-30-2004 12:09 PM
On the subject of cleaning, what tire dressing.. Z_OH_6 C5 Z06 Discussion 24 01-28-2004 10:45 AM
What do you use to black tires? Jeff Kirk Car Care Discussion 17 08-30-2002 09:23 PM
What do you use to get white letter tires WHITE? TonyQT C3 Tech/Performance 37 08-02-2002 05:54 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
