Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-04-2003, 11:03 AM   #1
c4cruiser
CF Senior Member
Support Corvetteforum!
c4cruiser's Avatar
Default C4 Wheel Adapters
I'm looking for a set of adapters in order to run some 17" American Racing wheels on my 87 for autocross use. These wheels came off a 92 so I should be able to use a 3/4" thick adapter like the ones in the catalogs.
Unfortunately, those types of adapters are for OEM-type Corvette wheels that have recesses in the mounting flange. It looks like that the acorn lugs used to bolt the adapters on the hub stick out and must fit into the 17" wheel recesses. My ARE wheels have a smooth mounting flange with no recesses.
Any ideas??
c4cruiser is offline   Reply With Quote
Old 03-08-2003, 10:20 PM   #2
USAZR1
CF Senior Member
USAZR1's Avatar
Default Re: C4 Wheel Adapters (c4cruiser)
Have you actually tried to mount the ARE wheels yet? They might fit without spacers.
USAZR1 is offline   Reply With Quote
Old 03-08-2003, 10:37 PM   #3
c4cruiser
CF Senior Member
c4cruiser's Avatar
Default Re: C4 Wheel Adapters (USAZR1)
They will bolt up with no problem; my concern is whether or not they will clear suspension components once tires are mounted. The Vette Brakes adapter I had looked at is 3/4" wide and is designed specifically for mounting late (88-96) wheels onto 84-88 cars with 16" wheels.
I might try swapping a pair of the AFS wheels from my 92 and see what that does. If there is sufficient clearance, then it will solve a lot of questions about tires I can run for autocross and open track events. I'm not sure if it's even a good idea to run adapters for track days or high-speed autocross.
Old 03-11-2003, 02:36 PM   #4
427t-top
CF Senior Member
Send a message via AIM to 427t-top
fI'm having the same problem, I bought a set of y2K's and they also have the flat flange..I was reading a Mustang catalog and saw that Stockton Wheel out of California carries a wide range of adapters..I'm going to contact them and will post what I find here :banghead:
427t-top is offline   Reply With Quote
Old 03-11-2003, 07:41 PM   #5
427t-top
CF Senior Member
Default Re: C4 Wheel Adapters (427t-top)
stockton tire in california can make an adapter that will work for us. they recommend 1 1/2" and will make them with the flat flange. Cost may be prohibitive though, they quoted me $333 shipped to central texas. I thinkk i'm going to do it anyway mainly because I really like the wheels and tires and I already have so much money in the setup. If you'd like, I'll let you know how it turns out.....
Old 03-11-2003, 08:19 PM   #6
c4cruiser
CF Senior Member
c4cruiser's Avatar
Thanks for the update. After talking to a couple of people, I am beginning to think that using adapters for open track events amy not be the best thing to do.
I'm going to think about some AFS 17x9.5" wheels that have the correct 38mm offset for the earlier C4's.
Reload this Page C4 Wheel Adapters
Tags
adapter, adapters, c4, stockton, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
wheel adapters, safe or widow makers??? The13Bats C4 Tech/Performance 21 09-19-2003 09:32 AM
C4 wheel adapters Black94LT1 C4 General Discussion 10 10-02-2002 10:13 AM
got shafted on ebay - 17 inch wheel adapters - will this stuff work lawcorvette C4 Tech/Performance 9 09-16-2002 03:24 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
