Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Wheels & Tires
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Wheels & Tires
Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option Sponsored by
Tire Rack
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-27-2003, 11:08 PM   #1
SvenOdin
CF Senior Member
SvenOdin's Avatar
Send a message via AIM to SvenOdin
Default Need Wheel Advice/Assistance....
Thinking about upgrading my wheels to 18 x 10 Front / 18 x 11.5 Rear (Tire sizes: 285/35-18 Front - 335/30-18 Rear "Michelin Pilot Sports")
The question that I have is will I need to do a mini-tub?? :confused: I'm sure the rears will stick out a little, but not sure if rubbing will occur.:skep:
Anyone running these sizes on their 'vette? How does it look, and most importantly, how does it perform?
Input appreciated!
:cheers:
SvenOdin is offline   Reply With Quote
Old 03-01-2003, 04:16 AM   #2
vrumvrum
CF Senior Member
vrumvrum's Avatar
Default Re: Need Wheel Advice/Assistance.... (SvenOdin)
This question keeps coming up. People have done it. I've never seen it personally so my opinion probably ain't worth much on this. I measured my C5 from the inside of the outer fender to the inner fender. You'll get 12.5"
A 335 tire is 13.5" wide, I had some on my truck. It needs to be mounted on a wider rim than 11.5" By mounting them on 11.5" you will be pulling the sidewalls in. Some say that will protect the rim. I have 295's on the back of mine. They are mounted on 11.5" wide rims. If you stand a yardstick against the sidewalls they line up with the outside of the fender.
I can barely slide my finger in between the inner fender and the sidewall.
That's about 1/2". To me, and it's just my opinion,
:troll :hat :conehead (<-that's me) that by pulling the sidewalls in, you are turning a 335 into a 295. A 335 is not designed to fit on an 11.5 rim.
http://corvetteforum.com/techtips/vi...D=36&TopicID=1
I'd go with tubbing if you don't have a vert and offset inward.
[Modified by vrumvrum, 6:38 AM 3/2/2003]
vrumvrum is offline   Reply With Quote
Old 03-04-2003, 10:56 PM   #3
SvenOdin
CF Senior Member
SvenOdin's Avatar
Default Re: Need Wheel Advice/Assistance.... (vrumvrum)
Thanks for your assistance.
I think I'll just have to suck it up and tub!
:cheers:
Old 03-05-2003, 01:24 AM   #4
vrumvrum
CF Senior Member
vrumvrum's Avatar
It'll look a lot better and won't sling crap all over the side of your car. :yesnod:
Reload this Page Need Wheel Advice/Assistance....
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
F'in Codes! Need help!!! YELLOHHH C5 Tech 9 08-15-2004 08:20 PM
(C5) SCCA / ASP guys - need help with large wheel/tire package JakeL Autocrossing & Roadracing 13 01-15-2004 12:16 AM
Rear End Noise...Need Technical assistance....Please help..... dmkc C5 Tech 14 08-03-2003 09:32 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
